February 13, 2026, 10:40:45 AM *
Author Topic: Adjustable levers?  (Read 1240 times)
« on: July 10, 2017, 10:15:37 AM »
My failing rememberer tells me that chrome wide blade wing levers (GoldWing) fit a Valk but my local supply shop says Kury doesn't make them. Can anyone tell me what they're using and maybe a part number too?
flash2002
Montreal, Que
« Reply #1 on: July 10, 2017, 01:15:57 PM »
Check this place.
              http://cyclemax.com/inc/sdetail/gl1800_chrome_wide_levers/117/246487
Stick
Sherbrooke Nova Scotia
« Reply #2 on: July 10, 2017, 01:39:19 PM »
I
Showchrome or big bike parts
2001 Valkyrie Interstate Burgundy/Black*Sold*
2000 Valkyrie Interstate-Black*Sold*
2000 Valkyrie Supervalk-Blue/Silver*Sold*
« Reply #3 on: July 10, 2017, 01:40:29 PM »
As I recall, the adjustable levers are/were for the 1800 Wing but will work on the Valk with a small modification. Part of a tab has to be removed in the area of the clutch switch or the plunger, forget just now but it's a simple fix.
Bagger John - #3785
« Reply #4 on: July 10, 2017, 02:37:04 PM »
Correct re: fitment.
I have them on both of my Valkyries and will take a look at what I did (it's been several years).
One thing you have to check is the thickness of the boss which holds the bronze bushing for the pivot bolt, as well as the length of the bushing itself. Mine required a slight amount of planing with a fine grit oilstone before it would fit the Valkyrie master cylinders without binding.
turtle254
Livingston,Texas
« Reply #5 on: July 10, 2017, 02:56:17 PM »
Will they fit on a 1998
Valkyrie
« Reply #6 on: July 10, 2017, 07:32:18 PM »
Thanks to all. Later today I found the cyclemax site. Gonna get them ordered tomorrow.
Bagger John - #3785
« Reply #7 on: July 11, 2017, 06:56:23 AM »
Valkyrie
Clutch and front brake master cylinders were the same for all model years of Valkyries so they'll work - with a bit of fine tuning as mentioned above.
« Reply #8 on: July 11, 2017, 01:20:35 PM »
My local service shop can order just the brake lever from BigBikeParts. That's the only one I need to correct a finger reach problem. My Kury grips, coupled with Kury levers, make the reach just a bit too far.
