February 13, 2026, 01:33:19 PM *
Author Topic: Coolant leak...again.  (Read 885 times)
msb
Agassiz, BC Canada
« on: July 14, 2017, 06:14:22 PM »
On the way home from Inzane the other week, noticed a small amount of coolant on the ground each time I stopped for a bit. Checked it out when I got home and noticed a crack in the upper "T" hose end where it attaches to the water pump. Ordered a new hose and installed, tightened up all the clamps, etc then went to pour the coolant back in and noticed a significant leak right away. Thought the one hose clamp on the Right side connection may be loose, but it didn't appear wet around there at all. Seems to be coming from where the hose port meets the block? (Blue arrow) Is there another source that may case it to look like this, or is this a potential leak point?
Appreciate any ideas, advice
Thanks, Mike
'99 Red  & Black IS
« Reply #1 on: July 14, 2017, 06:18:35 PM »
You need a new special o ring. Check the fishe. Easy cheap fix.
msb
Agassiz, BC Canada
« Reply #2 on: July 14, 2017, 06:49:45 PM »
Thx cooldude cooldude
'99 Red  & Black IS
