February 13, 2026, 12:21:45 PM *
Author Topic: Front turn signal: Cobra Lightbar  (Read 796 times)
DK
Little Rock
« on: July 23, 2017, 12:57:10 PM »
I need to replace the front turn signals on my Tourer. The signals are mounted on a Cobra light bar which uses a "modified" stock signal assembly. The attachment bolt screws into the top rather than the side of the stalk.
     Where can I find the modified turn signal assemblies?
     Can I modify a stock signal using part of the signal assembly I'm replacing?
matt
Derry New Hampshire
« Reply #1 on: July 23, 2017, 05:45:29 PM »
If I understand what your asking, you need that piece that goes thru bar and hold turn signal assembly? They are available on J&P cycles.  And yes you use original turn lamp assemblies
Bagger John - #3785
« Reply #2 on: July 24, 2017, 10:38:43 AM »
The set I have uses the first-generation ('97-'99) Honda OEM turn signal assemblies. These are the type which uses two screws to retain the lens.
You should be able to get a used pair of takeoffs from our Classifieds, from eBay and similar sources. There are turn-signal adapters (Cobra P/N 99-0575, among others) which are specifically designed to mount the OEM signals to Cobra-style bars.
