February 13, 2026, 12:21:34 PM *
Author Topic: Replacing Drive Shaft Seal  (Read 905 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
« on: July 27, 2017, 05:27:08 PM »
Any hints on how to replace Oil Seal (#16) on my Propeller Shaft for my 99CT...??? I was thinking of (gently) using a large vise grip to hold the spring tension off...I don't have a vise here but could use a friends if this is the only way to remove the Clip retainer...!!!
mrgeoff/SANDMAN
« Reply #1 on: July 27, 2017, 05:44:38 PM »
Hubcap made a little jig out of plywood and screws that looked like a good way to do it. Don't do it the way I did. Left hand pushing down on the spring and right hand using circlip tool. That was hard. I think 2 people could do it just fine.
mrgeoff
Augusta, GA.
« Reply #2 on: July 27, 2017, 06:38:56 PM »
Meathead...This gives me an idea...Cable Tie Wraps...a couple tied to the spring to relieve the tension just enough to remove the slip ring...If it works, I'll patent it and we will be rich...hahaha...but I will let ya'll know...Thanks...!!!
mrgeoff/SANDMAN
« Reply #3 on: July 27, 2017, 07:22:47 PM »
that's the way to do it, cable ties.
« Reply #4 on: July 27, 2017, 08:56:01 PM »
cooldude excellent idea  cooldude
