April 30, 2026, 05:52:54 AM *
Author Topic: Throttle Lock  (Read 4068 times)
idcrewdawg
Albuquerque
« on: July 30, 2017, 02:09:46 PM »
I saw on the Facebook Valkyrie 1800 page a throttle lock by Brake Away, and got it. Installation was pretty simple, and I test rode it today. Works great. They sell them on Amazon, but are better priced on the manufactures website.
Wayne Basso
« Reply #1 on: July 30, 2017, 03:49:19 PM »
That's what I put on as well.  Easy to install, easy to use.
bscrive
Ottawa, Ontario
« Reply #2 on: July 30, 2017, 07:07:08 PM »
I got myself a Go Cruise throttle control for when I don't want to put on my electronic cruise control.  It's cheap and works fantastic.  Only $14 CDN.
http://www.twistedthrottle.ca/go-cruise-throttle-control-device-for-1-bars?gclid=Cj0KCQjwh_bLBRDeARIsAH4ZYENtbk03JH0YvKfhxu_GNkuV9gqSCgiYMrcGwKDkKwtnS5azb24oxlUaAlLLEALw_wcB
Jambriwal
« Reply #3 on: July 31, 2017, 02:50:48 AM »
I have the go cruise throttle lock also.  Works fine for giving my hand a rest or to zipper sleeves on jacket etc. Great bargain and plastic doesn't rust.
dinosnake
« Reply #4 on: August 02, 2017, 07:41:33 PM »
I have a two-tone aluminum one, as I have heated grips and a Go Cruise seems to be the only throttle lock guaranteed to work.  Getting it initially adjusted is a bit of a pain but overall it works well.
« Reply #5 on: August 03, 2017, 08:25:04 AM »
Thanks to all am ordering a Go Cruse and may eventually order a Brake Away but wanted to try a simple solution first to see if I would really use it.
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #6 on: August 03, 2017, 10:19:34 AM »
Go for the aluminum $30ish US. will fit on any handgrip, worth double the price of the plastic, I did break one of those. The plastic works good though. Specify 1" bar if going cheap.
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
« Reply #7 on: August 03, 2017, 12:05:16 PM »
Thor32
A road less traveled- traveler
Rockford, IL
« Reply #8 on: August 08, 2017, 02:15:08 PM »
Dawg do you find it holds the speed consistently after utilizing?
Thor32
idcrewdawg
Albuquerque
« Reply #9 on: August 09, 2017, 06:09:00 PM »
I think so, but I also found myself clicking on and off a lot as I encountered traffic. It's also difficult to set to a given speed. Though I think that'll come with repeated use.
I installed it, tested it and then left town on vacation so I've not had a chance to ride any distance with it.
Wayne Basso
« Reply #10 on: August 09, 2017, 07:30:40 PM »
I find it is sensitive, but the speed tends to stay where it is set as long as you are on a flat stretch of road.  Any rise or drop and your speed will do the same because it just grips the throttle.  Mine is set so I can still twist the throttle as needed.
RSO
So Cal USA
« Reply #11 on: September 01, 2017, 12:09:52 AM »
What is the model # for the Brake Away? On the manufacturer site I only see it listed for the F6b.
Parkway440
« Reply #12 on: September 01, 2017, 03:42:36 AM »
7CP01 I've had mine for years still works perfect.
idcrewdawg
Albuquerque
« Reply #13 on: September 01, 2017, 07:17:41 AM »
That's what i put on. works great!
RSO
So Cal USA
« Reply #14 on: September 01, 2017, 10:44:13 PM »
Was it a direct fit for our new Valks? Any install issues while using the factory grips?
The Brake Away site list a different model # for the Goldwing F6B and no listing for the new Valk. 7CP01 seems to be a universal version for metric bikes. Just want to make sure you didn't have to modify to get it to work or fit properly. I emailed Brake Away for the appropriate version for a 2014 Valkyrie but haven't heard from them.
I am really interested in purchasing the Brake Away.
« Last Edit: September 02, 2017, 02:10:42 AM by RSO » Logged
Parkway440
« Reply #15 on: September 02, 2017, 04:52:15 AM »
Direct fit with factory bars and grips. Easy install with good directions. Very nice product!
idcrewdawg
Albuquerque
« Reply #16 on: September 02, 2017, 07:33:00 AM »
I have factory grips and bar. It fit without any needing of modifying the throttle lock or the bike. Super easy to install. There is an install video that isn't 1800 valk specific, but it shows what you need to do. Follow it, because the written instructions are not very clear. The video is under videos on the BreakAway website. The only thing I did differently than the video was I didn't have to move my brake reservoir as they did in the video.
RSO
So Cal USA
« Reply #17 on: September 02, 2017, 11:00:26 AM »
Thanks so much for the info. Gonna purchase today cooldude
RSO
So Cal USA
« Reply #18 on: September 09, 2017, 12:02:20 PM »
BrakeAway 7Cp01 installed! cooldude
My aluminum GoCruise was ok but this just says "Custom" all the way!
Typed in "7Cp01 installation" on youtube. I followed his 20 min video exactly and had no problems installing. Was much easier to watch the video than to use the included instructions.
« Last Edit: September 09, 2017, 12:39:50 PM by RSO » Logged
idcrewdawg
Albuquerque
« Reply #19 on: September 09, 2017, 03:52:38 PM »
Crabballs
« Reply #20 on: September 09, 2017, 05:28:08 PM »
Very nice!!!  I gotta get one!
