March 12, 2026, 07:40:20 PM *
Author Topic: Assy plug,  (Read 1222 times)
captsharky
Been riding Honda since 1972.
Sunrise, Florida
« on: October 21, 2009, 06:27:36 AM »
Does the Valk have an assy plug where I can plug my GPS wireing in, or does it have to be run back to the battery????
2001 Valk black Interstate,
1998 T Cobra light bar, Corbin seats  Tank bib, baker air wings, lockable hard bags, luggage rack and trunk. Woody's faring, cruise throttle lock.
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« Reply #1 on: October 21, 2009, 06:59:51 AM »
YOU have to make your own asc. plug, a cig. lighter wired into the batt. mount anywhere you can . mine is on the windshield.
PAVALKER
Pittsburgh, Pa
« Reply #2 on: October 21, 2009, 07:00:38 AM »
Accessory plugs have to be added. And I assume you mean Power Ports like a Cig Lighter.  You can run one from the battery or from under the right side cover (a key on power lead is there I think).... and mount one up front.  I have one I got at WalMart mounted under the top clamp, actually zip tied to the handle bars under the top clamp.  Works well for me.   I also ran one right out from under the passenger seat so I could charge the cell phone in the trunk or Bag of my IS if need be.
John
Blackduck KS
Atitude Is Everything
Wichita KS.
« Reply #3 on: October 21, 2009, 07:05:52 AM »
You can hide it under the seat thats where mine is. cooldude
Madmike
Campbell River BC, Canada
« Reply #4 on: October 21, 2009, 07:55:48 AM »
There is a 5 Amp accessory circuit under the right side cover, it is 2 wires inside a rubber sleeve.  You can use this as a power source or as a control circuit for a relay.
There are several styles of accessory power points available, here are some examples:
http://www.electricalconnection.com/power-distribution/pplug-main.htm
http://www.solarseller.com/low_voltage_dc_pumps__lvm__teel__accessories__plugs_and_extensions.htm
http://www.manicsalamander.com/mounted_connector.htm
http://www.kuryakyn.com/index.cfm/prodFam/metric/go/Home.ProductDetail/IMID/1054
captsharky
Sunrise, Florida
« Reply #5 on: October 21, 2009, 08:05:03 AM »
Ok, guess I worded it wrong, the VTX 1800 has an extra wireing plug in the head light to wire up assy's. I was wondering if the Valk had any such plugs that are already relayed. I want to wire up my GPS to the bike's system, and not have to add another relay. So it would be switch with the Key.
Sharky
SlowRoad
Hartselle AL
« Reply #6 on: October 21, 2009, 08:08:30 AM »
The wire under the right side cover will do what you are looking for. It is a fused circuit. Think it's a 5A circuit, so should handle a GPS.
Tim
« Reply #7 on: October 21, 2009, 09:00:28 AM »
Tim
Yeah, but it seems a shame to use it up on a single device, when it would run a big handful of relays...
« Reply #8 on: October 21, 2009, 10:42:02 AM »
bill pollock had one mounted inside his fairing on the right ride
I will edit this post when I get home with a pic of it
Most I have seen are under the seat tapped into the engine hangar covers
