January 29, 2026, 10:49:57 PM *
Author Topic: Did A search and can't find anything. Does the tourer come with the bigger tank?  (Read 2872 times)
Dumptruck
« on: October 21, 2009, 11:18:18 AM »
« Reply #1 on: October 21, 2009, 11:22:19 AM »
Std & Tourer have the same tank.
I/State has a larger one with the gas gauge provision.
Dumptruck
« Reply #2 on: October 21, 2009, 12:05:45 PM »
Thanks!
« Reply #3 on: October 21, 2009, 02:38:23 PM »
You CAN put an Interstate tank on a standard or tourer however.
MP
North Dakota
« Reply #4 on: October 21, 2009, 09:19:56 PM »
Put one on mine.  IS tank, repainted to match, and a Motosen fuel gauge.  Love it.
MP
"Ridin' with Cycho"
Puffs Daddy
« Reply #5 on: October 22, 2009, 05:31:46 AM »
MP
Just a note of caution regarding this conversion. Some seats, such as the Ultimate, designed for the Standard/Tourer will not fit if the Interstate tank is substituted.
sheets
Jct Rte 299 & 96, Calif.
« Reply #6 on: October 22, 2009, 06:02:02 PM »
Standard/Tourer - 4.3 available + 1 gl. reserve = 5.3
Interstate - 5.3 available + 1 gl reserve = 6.3
Change to aftermarket petcock = less reserve.
MP
North Dakota
« Reply #7 on: October 22, 2009, 08:58:29 PM »
Sorry.  The IS tank is 6.89 gallons, not 6.3, per the IS owners manual.
The quote from the literature on valkyrienorway.com is:
"Increased-capacity fuel tank holds 6.9 gallons for extended touring."
When I switch my IS tank to reserve, it will take 6 gallons to fill.  I have put 6.7 gallons in it, and it was still running fine.
MP
« Last Edit: October 22, 2009, 09:03:17 PM by MP » Logged
"Ridin' with Cycho"
G-Man
White Plains, NY
« Reply #8 on: October 23, 2009, 05:48:26 AM »
MP
Interstate tank with an Ultimate Kingboy on my standard..........no problems at all with the seat fitting.
« Last Edit: October 23, 2009, 05:50:18 AM by G-Man » Logged
Puffs Daddy
« Reply #9 on: October 23, 2009, 06:35:29 AM »
MP
Interesting. Several possibilities. (1) The "King boy" is shorter than the earlier versions of Ultimate such as the "Big Boy." Though I can't find the exact fore to aft dimensions on the Ultimate website, the fact that the King Boy seats the rider "farther back" suggests that might be the case. (2) You have an "Interstate" rather than a "Standard/Tourer" version of the seat on your bike. (3) Unlikely, but perhaps Ultimate has changed the dimensions of the "Big Boy" and "Low Rider" since I purchased mine some years ago.
I do know that several years ago when I considered purchasing an Interstate tank for my Standard, Ultimate advised me that the Big Boy seat I had would not fit (Too long.)  And they were obviously correct. My Ultimate seat fits very tightly against my Standard tank. With the slightly longer Interstate tank, it would not fit.
I do note that Ultimate still has separate pages for their "Standard/Tourer" and "Interstate" seats. So, perhaps the best advice is to check with Ultimate to see if there are still issues and what they are.
P.S. Sent an email to Des at Ultimate Seats regarding this issue. If he gets back to me, I'll post the response.
« Last Edit: October 23, 2009, 08:06:44 AM by Puffs Daddy » Logged
Black Sled
« Reply #10 on: October 23, 2009, 08:03:57 AM »
Please elaborate on "gas gauge provision".  I have a Tourer and would love to have a gauge.  Is there any way to add one without changing tanks?  Also, would the I?S tank be a direct bolt up?  Perhaps I should start looking for a Black I/S tank...
thanks
Black 2000 Valk Tourer (my black sled)
Puffs Daddy
« Reply #11 on: October 23, 2009, 08:11:02 AM »
Happened across the following link that others may find useful.
http://www.timskelton.com/valkyrie/how_to/tank.htm
Trynt
So. Cen. Minnesota
« Reply #12 on: October 23, 2009, 10:40:47 AM »
[/quote]
It fit on mine, but did push the nose of the seat up a bit.
Rocketman
Seabrook, Texas
« Reply #13 on: October 23, 2009, 11:20:35 AM »
I would recommend looking for an I/S tank, but bring money.  They're expensive these days.
The gauge requires a mounting hole on the bottom of the tank.  I'm not sure how folks calibrate theirs.
I suppose you could cut a mounting hole in the bottom of a standard tank and hook it up that way, but by then, I'd rather spend the money and get the extra capacity also.
As for bolt-up, yes, the IS tank should bolt up directly on a stock machine.  If you have the V-Stacks, they'll interfere.  The seat is a known problem, but I believe that the stock seat will fit, but the tank will push the nose of the seat up some.
« Reply #14 on: October 23, 2009, 03:06:55 PM »
Will a Mustang seat work with an Interstate tank on a standard/tourer?
junior
new hampshire
« Reply #15 on: October 23, 2009, 03:49:56 PM »
the tank is taller at the seat end and wider frm side to side it aint longer from end to end. cause if it was the mounting bolt holes wouldnt line up
Puffs Daddy
« Reply #16 on: October 23, 2009, 04:12:32 PM »
I think you're correct.
junior
new hampshire
« Reply #17 on: October 23, 2009, 04:42:53 PM »
i know i am cause i have done the upgrade on my 97 tourer and had to modify the nose of my corbin seat. had to trim about aa 1/4 of an inch off it  to make it lock into place  cooldude
i have pics if you want to see them
Puffs Daddy
« Reply #18 on: October 23, 2009, 04:57:47 PM »
I believe you. In this case, the issue was the Ultimate seat.
« Reply #19 on: October 23, 2009, 05:58:07 PM »
Does anyone know about the Mustang seat?
sheets
« Reply #20 on: October 23, 2009, 07:14:24 PM »
+/- 2.35 qts.  Educated guess.  My bad.  Ymmv,
(which could mean 20 miles further down the road).
(No, I wouldn't want to thumb-it 20 miles).   Roll Eyes
MP
« Last Edit: October 24, 2009, 04:48:44 PM by sheets » Logged
