April 02, 2026, 02:25:16 PM *
Author Topic: Only flat on one side  (Read 668 times)
vanagon40
Greenwood, IN
« on: August 04, 2017, 06:47:13 AM »
Went to put the bike in the garage last night, and this is what I found. At least it was in my driveway.
Small construction screw. I debated pulling the tire to patch it instead of plugging it, but:
     1) I currently do not have the O rings for the spline maintenance;
     2) I really do not have the time right now; and
     3) The battery on my old SilverWing is toast (beyond resuscitation).
I hated plugging it, as the hole started out the size of a small finishing nail and ended up big enough to shove a gutter spike into it. But I'm up and running until I have a chance to fix it proper.
« Last Edit: May 16, 2018, 11:59:14 AM by vanagon40 » Logged
« Reply #1 on: August 04, 2017, 08:13:37 AM »
I see car tires can get flats.
But following here for years, it seems there are far fewer flats in car tires than bike tires.
Keep checking pressure regularly for awhile.  If it holds steady, you are probably good to go.
« Reply #2 on: August 04, 2017, 08:21:08 AM »
I think I would pull it and put a patch or patch/plug combo on it when you have time. I hate that nagging feeling on a great ride thru the mountains knowing you've got a plugged tire.  coolsmiley
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: August 04, 2017, 08:30:32 AM »
Must be nice to have a center stand.
So many roads, so little time
VRCC # 5258
« Reply #4 on: August 04, 2017, 12:18:09 PM »
Sure is, you don't need a lift to pull the wheel or service the rear end.  cooldude
Sorcerer
Brooklyn Center MN.
« Reply #5 on: August 04, 2017, 01:12:32 PM »
How hard is it to get it on the center stand when the tire is flat.
« Reply #6 on: August 04, 2017, 01:18:04 PM »
Pretty much impossible for me. But it's easy to ride the back wheel up on some boards and do it. cooldude
RainMaker
Arlington, TX
« Reply #7 on: August 04, 2017, 01:49:43 PM »
I would need a winch to get a flat tired Interstate up on that center stand.  I'd have to air the tire up first, then put it on the stand.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
