February 13, 2026, 01:37:54 PM *
Author Topic: Rear lower fender swap  (Read 1018 times)
Romeo
J.A.B.O.A.
Romeo, Michigan
« on: August 04, 2017, 07:19:29 AM »
I want to swap my rear lower fender from my Tourer onto my I/S including the tail light.
My question is, is the wiring for the tail light in the harness that disconnects at the spot where the fender splits? I notice the connector on the interstate is hidden behind a metal cover of some sort.,
« Reply #1 on: August 04, 2017, 08:12:00 AM »
The standard/tourer also has the metal box. Unless it's been damaged.
Paladin528
« Reply #2 on: August 04, 2017, 09:23:32 AM »
I did this with a Fender I picked up online.  Fully equipped rear fender from a Tourer onto an interstate.  I had to buy the correct wiring harness to have everything hook up like it was designed.  Stuffing the connector into the box where the two halves meet was a challenge but it did fit.  Works like a charm now.
« Reply #3 on: August 04, 2017, 10:04:18 AM »
If you want the taillight, just swap that. The IS has a plastic plug for a tail light.
« Reply #4 on: August 04, 2017, 05:14:05 PM »
A complete intact rear fender from a std/tourer, with the OEM wire harness, should swap easily and plug right in.
Rear wire harness A & B is different for an IS and a std/tourer.
