February 13, 2026, 01:38:00 PM *
Author Topic: Water leakage  (Read 1700 times)
joker
New York
« on: August 06, 2017, 12:49:55 PM »
Just fired the young lady up, and after a few minutes, I noticed water/steam bubbling out from the top of the left valve cover.
Should there even be coolant in there?
« Reply #1 on: August 06, 2017, 01:47:03 PM »
Sure there is a lot of coolant there. Two water pipes and the thermostat. You need to get up in there with a flashlight and try to track down where the leak is coming from.
My friend had water on top of the motor, it turned out to be a cracked thermostat housing, the top part that is plastic.
« Last Edit: August 06, 2017, 02:33:30 PM by Chrisj CMA » Logged
joker
New York
« Reply #2 on: August 06, 2017, 02:33:33 PM »
I see exactly where it's coming from. Between the seam of the valve cover and the engine. Bubbling thru the gasket, but I imagine there's more inside the cover, 'cause inside is supposed to be valves etc.  ..... right????
« Reply #3 on: August 06, 2017, 02:48:34 PM »
Not saying I don't believe you but that would be very unusual and in my opinion if true means a cracked head.
I'd take that valve cover off and do a detailed inspection.
If there is water in there and you can't see where,  I would even consider tarping off around the head and briefly run it without the valve cover.
My expectation is the water is coming from on top of the block but appears to be coming out of the cover.
Savago
Brentwood - CA
« Reply #4 on: August 06, 2017, 04:21:10 PM »
+1 on what Chrisj said: it is quite common that coolant leaks will originate on the hose that is on top of the engine.
A photo:
https://goo.gl/photos/qdHDTdobm31darF39
The fix is just to re-torque the hose clamps.
joker
New York
« Reply #5 on: August 06, 2017, 04:37:46 PM »
Well I certainly hope that's all it is. Going to run it again and take a closer look.
joker
New York
« Reply #6 on: August 06, 2017, 04:57:14 PM »
Ok. Trying to post a pic but  Photostash won't allow me
Pretty sure my number is 635. Is it the password for this site??
Moonshot_1
« Reply #7 on: August 06, 2017, 08:58:02 PM »
No, there shouldn't be. What does your oil look like? Does the oil on the dipstick look clean and normal or pale and soapy looking?
If normal, then the water/steam is originating from elsewhere.
In my opinion anyway.
Mike Luken
Cherokee, Ia.
joker
New York
« Reply #8 on: August 07, 2017, 03:30:02 AM »
Whatever it is, 18 years old, I'm afraid I'm going to have to bury her.
Bone
« Reply #9 on: August 07, 2017, 04:26:34 AM »
Still a teenager she'll make a couple of mistakes.
« Reply #10 on: August 07, 2017, 07:38:42 AM »
Joker, did you remove that valve cover yet?  I'm am very curious to know if you found any evidence of coolant inside.  Also the question Moonshot asked about the oil is a good one.  Have you evaluated the oil for signs of water there?
joker
New York
« Reply #11 on: August 07, 2017, 09:08:33 AM »
 I have not been home since this thread was posted, I would like to post a picture but I cannot get photostash to work.
« Last Edit: August 07, 2017, 09:13:14 AM by joker » Logged
« Reply #12 on: August 07, 2017, 08:50:53 PM »
My 1st thought was water in the spark plug well. Plugged drain hole through the head.
I would wonder why water would be coming from the gasket.
I would start by checking the oil for water.
« Last Edit: August 07, 2017, 09:12:36 PM by gordonv » Logged
joker
New York
« Reply #13 on: August 08, 2017, 01:54:21 AM »
Water in spark plug well ???!!!???
The bike was out in a torrential down pour the other day.
Good call. Gonna check that out.
Fingers crossed.
« Reply #14 on: August 08, 2017, 05:00:38 AM »
Ok water in the sparkplug well is not that unusual.  Blow the water out with air and then get a small wire and clear the drain hole for the sparkplug well.  Check all of them.  Easy
joker
New York
« Reply #15 on: August 08, 2017, 06:15:19 AM »
 Did not even know there were drain holes. Boy learn something new every day. Cannot wait to go home and check it out.
joker
New York
« Reply #16 on: August 08, 2017, 03:06:19 PM »
 OK, just got home pulled the plug out with the plug wire I should say and while it is dry in the well, the plug is all rusted and there is evidence of a lot of rusty water being in there. It's probably all evaporated by now
Cannot do it tonight, but I'm going to blow out the wells and clean out the drain holes. Running the bike now and there is no more leakage.
Thank you all for your help so much
« Reply #17 on: August 08, 2017, 04:28:51 PM »
If I remember correctly, which I don't, a lot, it's easier to see the holes from under.  A piece of baling wire pushed up worked the best for me.
« Reply #18 on: August 08, 2017, 06:46:32 PM »
+1 this was my second suggestion. Easier to find from underneath.
Rusty plug, sounds like water in there. Just might be the problem.
joker
New York
« Reply #19 on: August 09, 2017, 05:32:46 AM »
Well, well. The well is dry. Running the engine, no more water, steam. That was the problem. Now when you say clean the drain hole from underneath is that underneath the bottom of the valve cover?
 Boy, I would love to live in an alternate universe where I could have brought this to a Steeler find out how much they would have charged me to find out it was rainwater. LOL.
« Reply #20 on: August 09, 2017, 06:40:33 AM »
Look in one that is clean inside and you can see the hole.  Maybe easier to see with the spark plugs removed
joker
New York
« Reply #21 on: August 09, 2017, 06:56:46 AM »
Copy that. Thanx.
« Reply #22 on: August 10, 2017, 05:12:08 PM »
The hole goes through the head, from the bottom of the spark plug hole.
I found it easier with an IS to find the hole from the underside of the head, and using a smaller than the hole wire, push up gently.
joker
New York
« Reply #23 on: August 11, 2017, 06:31:59 AM »
  Copy that. Thank you everyone for your information and help
