April 04, 2026, 04:51:16 AM *
Author Topic: (Reposted on Tech Board) Got My Alternator Out  (Read 693 times)
Alberta Patriot
« on: August 08, 2017, 09:34:04 AM »
Is there an easy way to check the wire connections for conductivity. I just want to make sure the wires are not the issue...where do the connecting wires run to from the alternator so I can just do a test light check(Interstate)
Also...is the Golwing unit the same capacity as the Valk Interstate.
« Last Edit: August 08, 2017, 11:55:49 AM by 7th_son » Logged
« Reply #1 on: August 08, 2017, 11:27:18 AM »
You  might get a better and quicker answer to this on the Tech Board.
I can't answer your original question.
I can tell you that a Goldwing alternator will work if you "Turn the Clock".
There is info on the tech board about how to do that.
Alberta Patriot
« Reply #2 on: August 08, 2017, 11:42:12 AM »
Thanks, I have seen a few comments about 'turning the clock'... looks simple enough. I was just wondering if the I/S uses a higher output unit than the standard/tourer.
I spun the armature by hand...bearings run smooth, no play at all. The rubber cush blocks look good.
Going to repeat the post on the Tech Board.
« Last Edit: August 08, 2017, 11:45:27 AM by 7th_son » Logged
