Alberta Patriot
« on: August 08, 2017, 11:51:03 AM » |
Is there an easy way to check the wire connections for conductivity. I just want to make sure the wires are not the issue...where do the connecting wires run to from the alternator so I can just do a test light check(Interstate) Also...is the Goldwing unit the same capacity as the Valk Interstate. I spun the rotor by hand and the bearings feel smooth with no play. The cush blocks also look fine. Thanks
« Last Edit: August 11, 2017, 01:02:17 PM by 7th_son »
« Reply #2 on: August 08, 2017, 05:57:14 PM » |
unless u pull it apart, u cannot tell if the rear bearing is still good. did mine a few months ago. 52k, spinning that bearing by hand with my ear to it, I could hear looseness, didn't feel right either. used a bearing from NAPA which is for alts. brushes were not even close to the wear/replacement lines. in another 50k I'll pull it again.
« Reply #3 on: August 08, 2017, 06:50:56 PM » |
Chapter 16 in the service manual. If you don't have, you can get a PDF copy from Norway. I still have a hard copy, which I carry on trips, incase I need it. http://valkyrienorway.com/download.html
vanagon40
« Reply #4 on: August 08, 2017, 07:46:02 PM » |
You might check this thread.There used to be a lot of information and photos in the old tech archives, but I believe those no longer exist (and the photos would likely be gone anyway). There was problems with broken windings that some very resourceful people repaired. For a rebuilt, you might check M.A.R.S.
Alberta Patriot
« Reply #5 on: August 09, 2017, 12:48:03 AM » |
I did download the manual a while back, and it is helpful in many ways, but the wiring pages are not much help as they are very low resolution scans. I did find much better diagrams though here: http://www.rattlebars.com/valkfaq/schematics/I am going to take the alternator to have it tested and rebuilt as it seems to be the best option, as the after market ones on amazon sound like chinese built crap with crap components that I think will get me stranded. The local shop I am going to use gets excellent reviews online.
« Reply #7 on: August 09, 2017, 09:40:25 AM » |
Which shop? Years ago a shop with a good reputation (Bata's Electric) was unable to disassemble my Valk's alternator rotor to rewind it. I ended up having one sent to me by Medicine Hat Moto Sports.
Alberta Patriot
« Reply #8 on: August 09, 2017, 01:31:43 PM » |
Canadian Alternators & Starters: http://www.canadianalternatorsandstarters.com/I took the unit to them today around 10:00 and got a call back around 2:30. The rotor wiring failed, so they will rewind that and install new brushes...$175. I will update when I install it sometime Friday or Saturday.
« Reply #9 on: August 09, 2017, 03:36:52 PM » |
Canadian Alternators & Starters: http://www.canadianalternatorsandstarters.com/I took the unit to them today around 10:00 and got a call back around 2:30. The rotor wiring failed, so they will rewind that and install new brushes...$175. I will update when I install it sometime Friday or Saturday. make sure they check that rear bearing while its apart.
Alberta Patriot
« Reply #10 on: August 09, 2017, 05:26:16 PM » |
He said that he will check and replace anything that is suspect. This guy just seemed 'matter of fact' rather than the hesitant tone that I got from a couple other guys I talked to. I like positive attitude.
« Reply #11 on: August 09, 2017, 05:35:25 PM » |
Tip: thread locker on outer bearing sleeve. GL1500 Alternator Bearings. The rear bearing on the Goldwing (1500) alternator can wear prematurely, the first sign of this is when a wobbling noise comes from the engine at around 2,500 rpm. This is a distinctive sound which if ignored can lead to the whole bearing spinning and wearing away the alloy in the rear cover, leading to costly replacement. The bearing is a NSK 6000DU and it's equivalent only costs a few pounds from your bearing supplier. When fitting the new bearing, a drop or two of thread locking compound on the outer area will prevent spin, assuming that the cover is not already scrap. This picture shows a knackered bearing and you can see the burn marks where it spun in the cover. The cover in this case had to be replaced. http://homepage.eircom.net/~wingnut/GoldwingTips.htm
Alberta Patriot
« Reply #12 on: August 11, 2017, 01:15:12 PM » |
I picked up the rebuilt Alternator this morning around 10:00. Installed it and just finished a test ride. When I first started the bike...with the headlights facing the garage door and saw them brighten a little when I revved the engine, my wife gave a smile and a thumbs up. The alternator was in good shape other than the rotor according to the tech, but he replaced the bearings and brushes as a matter of course. He commented that he thought the wire used for the rotor windings was too thin....anyway, I am back on the road.
