November 14, 2025, 05:20:29 AM *
Author Topic: Dirty Crankcase Breather Storage Tank  (Read 1460 times)
dchester4
NE, USA
« on: August 09, 2017, 07:16:41 PM »
My crankcase breather tank is oily and dirty.  Real thick, oily, dirt that I had to rub off.
I got it all cleaned up, and am wondering is this a sign I should be taking care of something else?
The little tank itself, the large tube coming into and and exiting it were all the same.
I was replacing the vacuum tubes on the left side at the time...
Dan.
Ride on my friend....
« Reply #1 on: August 10, 2017, 04:06:59 AM »
Draining the dragon drool hose and making sure all the hoses are in good condition and hooked up correctly is about it.
dchester4
NE, USA
« Reply #2 on: August 10, 2017, 07:16:03 AM »
I did get about a tablespoon or so of drool out of there.  I planned to give all those hoses a better inspection/cleaning when I pull the airbox shortly.  Thanks.
1NorthRyder
Elliot Lake, Ontario, Canada
« Reply #3 on: February 14, 2019, 12:35:29 PM »
I wanted to resurrect this older post as I have also found the lines to be dirty and want to clean them. I want to know if you can clean the inside of the crankcase breather tank? When the hoses are removed and I look in it appears to be very dirty but I wasn’t sure I should remove it and try to clean the inside. Has anyone done this?
