December 17, 2025, 11:45:49 AM *
Author Topic: Still searching  (Read 1526 times)
Thunderbolt
Worthington Springs FL.
« on: August 10, 2017, 03:24:03 PM »
Went to Mike's yesterday and picked up the spare carb bank.  So today I tore into my carbs at about 0900 along with the heat and the bugs.  Cleaned everything, checked the usual stuff, set the pilots where I normally do at about 2 1/4 turns out.  Replaced the one diaphragm that had a split.  Put in new plugs and Mike also gave me an almost new set of intake o-rings that I installed.  I synced the carbs but I still have a random pop, seems like it is not necessarily one cylinder.  Now seems to be on the left side more than the right.  I haven't tried a test ride yet.  But here are a couple of things that I have been mulling around.  The spark plugs that I pulled out all had the first 1/32" of the center electrode burned to half the thickness of original.  I am still using the last tank of gas that I bought in Deadwood S.D. and parked the bike shortly after filling up and then transported it home in the toyhauler.  Aside from it being 3 months old does anyone have any experience with different blends of gasoline for different parts of the country?  I am going to drain the tank tomorrow and pour that in my old International Cub tractor, that thing will run on anything.  I'll fill it with non ethanol tomorrow and see if that helps.  Got me puzzled.  I didn't find anything out of the ordinary other than the one split diaphragm.
Any thoughts?
sixlow
St. Augustine, Fl.
« Reply #1 on: August 10, 2017, 03:59:37 PM »
I think it was Pappy that used a propane torch, NOT LIT, open the valve some and aim it at some carb areas while running to see if rpm's pick up.
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: August 10, 2017, 04:58:53 PM »
Different parts of the country use different blends of fuel that goes along with additives for Different times of the year. I would try new gas,a new set of plugs and if the popping is still there, check your valve adjustment. Are both sides of the engine popping, if not it could be exhaust gaskets bad, or loose pipes too. The popping on my Sabre went away when I replaced the exhaust doughnuts.
2001 black interstate
2003 Jupiter Orange wing
Thunderbolt
« Reply #3 on: August 11, 2017, 01:14:57 PM »
O.K. I could just stretch the truth a bit and say that I had a hole in one of the vacuum caps.  Roll Eyes  Or I could just tell the truth and say that I left one of the vacuum caps off after I synced the carbs.  Embarrassed  So if you ever have this popping noise on one cylinder and you follow that pipe back and see which cylinder it is you might look at that vacuum cap for a leak or see if it has taken a vacation.  cooldude
Running fine now.  Oh and the new gasoline couldn't fix that vacuum leak.  I think the original problem on the other side was actually one of the cheap o-rings that I had stuck in last time it was done.  But then there was that crack in the diaphragm that thanks to Bert and Mike I have replaced.  Here's the crack in the diaphragm, I stuck a small piece of paper in the crack to enhance it.  The crack wasn't that large to begin with but you could see it if you stretched it a bit.
sixlow
St. Augustine, Fl.
« Reply #4 on: August 12, 2017, 04:15:59 AM »
I'm glad it was an easy fix, sounds like the ol gurl doesn't want to leave home !  ???  Where does the sale stand now ?
Thunderbolt
« Reply #5 on: August 12, 2017, 11:34:42 AM »
Back on for the 25th Mike thanks again.  I'll catch up with you on the other things before long.  We are taking another trip soon so it might be a bit.  If you want I'll mail the carb bank back before we take off.
sixlow
St. Augustine, Fl.
« Reply #6 on: August 12, 2017, 01:48:49 PM »
No need to ship that back, have a great trip and touch base when you get back. cooldude
Bert AKA,Valkaholic
Back-N-Black
« Reply #7 on: August 13, 2017, 05:19:34 AM »
I Am Glad To Hear That You Got The Fat Gurl  Purring Again !
