February 13, 2026, 01:39:39 PM *
Author Topic: Front wheel bearings  (Read 1071 times)
« on: August 10, 2017, 07:26:52 PM »
replacing front tire, found right side bearing is bad. only 54k miles.
 anybody else have a short life bearing?
what is the best bearings to get and from who?
thanks
mark81
Cincinnati Ohio
« Reply #1 on: August 10, 2017, 07:42:31 PM »
I replaced the front bearings on mine a few months ago around 60k miles. Also rf bearing that went out. I used all balls kit with bearings and seals because it was in stock at local honda dealer. I have used their wheel bearings and fork seals in the past on other bikes with 0 issues.  I just chalked it up to 97 having smaller front bearings than other years.
1997 Honda Valkyrie
1981 Honda CB750 Custom
« Reply #2 on: August 11, 2017, 04:13:30 AM »
Sometimes the spacer inside the wheel interferes with checking the bearing.  I'd double check it is rough turning and not because of the spacer.
« Reply #3 on: August 11, 2017, 07:24:13 AM »
yep did that. its the bearing.  installed the axle, through the forks, slides right in, doesn't seem to be misaligned.  Left side bearing is nice and smooth.
found these SKF bearings. H indicates Viton seal.
http://www.ebay.com/itm/6204-2RS-SKF-Deep-Groove-Bearing-2RSH-2-Rubber-Seals-20mm-x-47mm-x-14mm/332082833482?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
