February 13, 2026, 02:06:38 PM *
Author Topic: An OIL LEAK question  (Read 1306 times)
Earl in Pensacola
« on: August 17, 2017, 06:16:11 PM »
Several years ago my '97 Tourer developed an oil leak which appeared to be coming out of the water pump.  I bought and installed a new pump, but I'm pretty sure that I discovered that the only problem was the little "O" ring inside had broken and replacing only the "O": ring will cure the leak.  It was so ong ago that I'm just not SURE about that. I'm asking if anyone else has experienced this oil leak and was/is the problem cured by replacing only the "O" ring? John Moore just E-mailed me asking about the very same leak problem and I don't want to steer him wrong.
Please PM me (justmeedp@cox.net) with your answer and I'll get back to him ASAP.
TIA
Earl in Pensacola
« Reply #1 on: August 18, 2017, 06:24:50 PM »
Ever get an answer ?
« Reply #2 on: August 19, 2017, 06:04:02 AM »
I was wondering also.
The parts diagrams only shows the LARGE o-ring that goes around the base of the water pump.
91302-MB0-013 O-RING (32.95X2.62)
There is no o-ring showing near the slot of the water pump shaft, nor is there one showing at the end of the oil pump shaft.
If there's one in there, I don't remember, as I only replaced 1 water pump and that was 14-15 years ago.
« Reply #3 on: August 19, 2017, 07:57:46 AM »
I believe the O-ring seen in this picture is the one that if failed may allow an oil leak.
RonW
Newport Beach
« Reply #4 on: August 19, 2017, 08:25:59 AM »
is that table (above) a mold for golf balls?
2000 Valkyrie Tourer
« Reply #5 on: August 19, 2017, 08:47:29 AM »
No lol.  The table is molded concrete.  I did use plastic golf balls to make the divots.  Its actually a Hawaiian checkers board..
If you never seen one, its played with colored rocks and all the holes are filled in. Its a neat game
RonW
Newport Beach
« Reply #6 on: August 19, 2017, 09:00:20 AM »
alrighty.
Apologize for the hijack, Earl.
Earl in Pensacola
« Reply #7 on: August 20, 2017, 04:54:29 AM »
Thanx for all the replies.  I forwarded info to John and will send him a notice to check this site. The pix Jeff displayed will be a lot of help to him.
