February 13, 2026, 02:06:39 PM *
Author Topic: OEM shock reset  (Read 1107 times)
Roidfingers
Tuscaloosa, Alabama
« on: August 19, 2017, 04:00:52 PM »
So, I have a 98m standard. My shocks have no decals. How do I determine what setting they are at. I want to lift it and go back to setting 1, on both , and then set to 4. TIA
WintrSol
Florissant, MO
« Reply #1 on: August 19, 2017, 06:34:53 PM »
According to my Owner's Manual, the numbers go from left to right, so turning the adjustment CCW, looking down from the top, should decrease it to 1; that would be rotating the left shock towards the back, the right towards the front. It should stop at 1 and not go any farther. If they are like other Honda shocks, turning past 5 will cause it to jump back down to 1, which isn't really a good idea; don't know, as I have the Goldwing air suspension, installed by the previous owner.
Check out p.17 in this: http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/GL1500C-1997.pdf
It's the same for the '98.
Hope this helps.
Rick
« Last Edit: August 19, 2017, 06:39:47 PM by WintrSol » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: August 20, 2017, 06:51:16 AM »
No harm done by going past 5 until it bangs back to #1. It's a shock that carries a Valk and loads. If a bang from 5 to 1 hurts it, I darn sure don't want to ride on something so fragile.
