February 13, 2026, 02:06:48 PM *
Author Topic: Side stand bolt  (Read 2840 times)
Tfrank59
'98 Tourer
Western Washington
« on: August 22, 2017, 07:47:35 PM »
Anybody had one break? Saw a post on here that OE is not even a grade 8 so I'm thinking about changing mine before it breaks.  Maybe I'm just paranoid but it's a lot of weight on that thing
-Tom
« Reply #1 on: August 22, 2017, 07:52:49 PM »
I've heard of the side stand SPRING bolt getting snapped off, I've done it twice.
Never heard of the side stand bolt breaking.
Fazer
« Reply #2 on: August 23, 2017, 06:17:35 AM »
I have a spare spring and bolt just in case.  Not very expensive and easy to carry in saddlebag.
Nothing in moderation...
« Reply #3 on: August 23, 2017, 09:43:39 AM »
grade 8 is not a metric grade, besides that, grade 8 is not always the way to go. grade 5 is better for constant flexing.  use oem part here.
Tfrank59
'98 Tourer
Western Washington
« Reply #4 on: August 23, 2017, 11:55:47 AM »
Beg to differ, grade 8 is heat-treated 4140 you can't beat that for this application
-Tom
« Reply #5 on: August 23, 2017, 01:08:11 PM »
so are you putting over 116030psi pressure (grade 8.8 oem) min tensile strength on it, to cause it to fail?
I haven't heard of a large failure rate on this part except from riders who hit a curb or steep driveway.
will grade 8 at over 150000psi min tensile cause the support structure to fail before the bolt does? easier to deal with a broken bolt on the road than the support structure. sometimes certain parts are designed to fail before offers, for easier repair and/or replacement. this is a good engineering practice. something to think about.  Smiley
« Reply #6 on: August 23, 2017, 01:22:48 PM »
I think you guys are talking about different things.  The thing that breaks is the spring hook, 50536-MZ0-010, which is not a standard bolt, but an application-specific part.  I'm pretty sure it doesn't have a strength grade like a standard bolt.  I've broken it once, and carry that part and a spring in my trip toolkit as spares.
« Last Edit: August 23, 2017, 01:24:40 PM by Gryphon Rider » Logged
cheeseman1969
Hastings NE
« Reply #7 on: August 23, 2017, 03:49:56 PM »
Hook, I just posted that I sheared off my bolt for the spring, not to the kickstand. What part did you order? I can't find it on the microfic
Gary "Cheeseman"
USN "weather guesser" Retired
Been everywhere...
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: August 23, 2017, 04:55:50 PM »
I don't know how much sheer pressure is on that pivot Bolt but I'm sure it's in the thousands psi focused on that little point. I'm not doing anything weird with my bike that would cause a failure like that in fact I baby that kickstand. frankly I'm more worried about the sidestand itself which is a forging snapping than I am either the pivot Bolt or the mounting bracket.
-Tom
« Reply #9 on: August 23, 2017, 05:26:45 PM »
#11
http://www.partzilla.com/parts/search/Honda/Motorcycle/2000/GL1500CT+A/FRAME/parts.html
Ramie
2001 I/S St. Michael MN
« Reply #10 on: August 24, 2017, 08:45:44 AM »
Metric grade 8.8 is the same as SAE grade 5.
« Reply #11 on: August 24, 2017, 09:16:40 AM »
not exactly, but close
  https://www.boltdepot.com/fastener-information/Materials-and-Grades/Bolt-Grade-Chart.aspx
grade 8.8    116,030 psi
grade 5      120,000psi
http://www.theunitconverter.com/psi-to-megapascal-conversion/800-psi-to-megapascal.html
« Reply #12 on: August 24, 2017, 10:13:46 AM »
I think if you drag that bolt going over a speed hump (or something), it's going to break regardless of the bolt quality.
You think any strength bolt is going to jack the (850lb) bike up onto a hop?  Or drag a groove through the blacktop?
I think having spare spring and special bolt on board is a good idea, and a zip tie (or short bungee) to hold the side stand up if you just want to get home and fix it there.
« Reply #13 on: August 24, 2017, 11:34:02 AM »
 cooldude cooldude cooldude
