February 13, 2026, 02:06:32 PM *
Author Topic: Tank vent tube connection  (Read 2900 times)
CG
« on: August 24, 2017, 10:25:51 AM »
Recently pulled tank.  The vent tube towards the rear of the tank has a hose connected that traveled out the bottom of the valk with the other "breather" type tubes.  However, there was an inline T and that middle connector wasn't connected to any tube but it looks like it calls for it?  Any ideas of what hose this is supposed to connect too?  I don't see one laying anywhere to be attached?  Thanks......
« Reply #1 on: August 24, 2017, 10:57:11 AM »
It's not hooked to anything, on purpose.  It's a breather deal.  You're good.
DeathWishBikerDude
« Reply #2 on: August 24, 2017, 12:10:21 PM »
Any images?After replacing my tank I need a penny on the fuel tank gasket to keep from stalling..lol..cheap anti theft system... Lips Sealed
« Reply #3 on: August 24, 2017, 01:32:24 PM »
The tee is #2 below.  The picture doesn't show it, but the upper of the two #28's connects to the nipple on the underside of the back end of the fuel tank.
« Reply #4 on: August 24, 2017, 04:02:01 PM »
Sounds like you kinked the vent line when you installed the gas tank.
« Last Edit: August 24, 2017, 06:57:43 PM by Chrisj CMA » Logged
« Reply #5 on: August 24, 2017, 04:05:27 PM »
It's purpose is to prevent water from being sucked up the hose, while riding in the rain, shutting down the venting of the tank, thus causing gas starvation.
The reason I know this is because back in 2000 -2001, I removed mine thinking it was a mistake.  I made the mistake and found out it's purpose the next time I got caught in a rain storm. uglystupid2
CG
« Reply #6 on: August 24, 2017, 06:23:31 PM »
As always the VRCC group comes through.  Can't thank you enough.  I'll quit looking for a line that doesn't exist and leave as is!
I'm into the fat lady a bit with the tank off, air box off, replacing vacuum lines etc. and I'm more impressed with her design the further I get.  What a marvel to conceive...
On another note, if anyone has spare intake manifold bolts(chrome), I/m missing 6.....They simply weren't there when I purchased her and I never noticed before.....Another potential vacuum issue source:)  Thanks again guys.
« Reply #7 on: August 24, 2017, 06:29:15 PM »
http://www.partzilla.com/parts/detail/honda/HP-90022-MZ0-000.html
Kinda pricey, but this is what you want to use.
CG
« Reply #8 on: August 24, 2017, 06:49:25 PM »
Man I love this site!  Thanks HOOK#3287............Big help
Steel cowboy
Spring Hill, Fl.
« Reply #9 on: August 24, 2017, 07:18:45 PM »
If your missing 6 bolts, 3 on either side, the P/O might have had the chrome spark plug covers and removed them. You have to replace 3 chrome bolts on either side with their bolts to install them.
2001 black interstate
2003 Jupiter Orange wing
