February 13, 2026, 06:44:42 PM *
Author Topic: Bigbikethings Forward Controls  (Read 1660 times)
Harryc
Sebastian, Fl
« on: September 03, 2017, 05:48:13 AM »
I need a large favor. Can anyone with Bigbikethings (crashbar located) forward controls take a few pics of how they mount on both the shifter and brake side? I recently picked up a used set (version 1) and while it did come with written instructions, they are pretty bad and a pic is worth a thousand words. The most help to me would be pics of how the square tubes up front mount to the frame and/or crash bars.
« Last Edit: September 03, 2017, 05:51:34 AM by Harryc » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #1 on: September 03, 2017, 10:57:59 AM »
Can't help, but you do know there are two different sets. ? One set will not fit the Interstate.
DeathWishBikerDude
« Reply #2 on: September 03, 2017, 11:03:02 AM »
Junk,garbage,gerry rigging is the basic install..they mod that junk.
DeathWishBikerDude
« Reply #3 on: September 03, 2017, 11:05:10 AM »
I took mine off after a short time and threw that cheap bathroom towel tubing in the trash.just return that garbage.
« Reply #4 on: September 03, 2017, 11:20:35 AM »
2funny I don't know what to make of you DWBD.  Smiley
Harry, I wish I could help. I tried pulling up some pics, but couldn't find anything with a closeup. If by some chance you decide to take DWBD's advice, send them my way. I'll take them off your hands.   2funny Also, post this over on the general board too. Cast a wide net.  cooldude
DeathWishBikerDude
« Reply #5 on: September 03, 2017, 11:29:02 AM »
Seriously,I could make better stuff in high school machine shop.Please post photos of the high quality forward controls..so everyone can see that junk.
Harryc
Sebastian, Fl
« Reply #6 on: September 03, 2017, 02:24:26 PM »
Thanks for nothing. Next time you ask for something here I'll definitely make a mental note to ignore it. @Meathead, thanks I appreciate it Bro.
« Last Edit: September 03, 2017, 02:26:56 PM by Harryc » Logged
DeathWishBikerDude
« Reply #7 on: September 03, 2017, 02:35:27 PM »
I'm telling you truthfully,return it.
It's nearly impossible to install,needs constant adjustment,never works properly,and looks terrible.
Please post some up close photos so others can form an opinion.
Harryc
Sebastian, Fl
« Reply #8 on: September 03, 2017, 02:43:15 PM »
I am no fabricator. This set is the only game in town. Make me a set and I'll take pics and post them here with an honest opinion.  I need forwards because I am 6'6" tall on a bike built for smaller folks... end of discussion.
DeathWishBikerDude
« Reply #9 on: September 03, 2017, 03:00:50 PM »
First find a way to magnitize an open end wrench or maybe try a gear wrench,there is no room for fingers when mounting the bathroom towel holder to the frame.
Once you spend 3 hours mounting that attach the bracket to the shift peg.
Then attach the linkage from shift peg to the actual forward control lever.
Probably another 3 hours to figure this part out,leave everything finger tight,youll be readjusting as necessary.
Once you figure where everything goes,go for a ride,youll probably notice you don't have enough travel to complete a shift,youll get neutral or a loud clunk.
Make more adjustment to shorten or lengthen the shift,probably have to add washers and or spacers to get proper operation.
After all this expect the hardware to loosen daily and require readjustment.
Double nut everything.
Enjoy
DeathWishBikerDude
« Reply #10 on: September 03, 2017, 03:38:35 PM »
Ugh.
« Last Edit: September 03, 2017, 03:40:07 PM by DeathWishBikerDude » Logged
« Reply #11 on: September 03, 2017, 03:47:25 PM »
I've had 'em for 10 years, use them all the time. When I ride
the 1800, I miss them. They're awesome  cooldude
I cut the square bar short, got rid of the part on each side at the
curve... I don't use it for footpegs, just for it's clamping action...
« Last Edit: September 03, 2017, 03:52:11 PM by hubcapsc » Logged
Harryc
Sebastian, Fl
« Reply #12 on: September 03, 2017, 04:48:11 PM »
Very cool Mike, and thanks for the pic. I am getting a good idea of how these are installed up front. I had to order some 3/8" foot peg clevis's because I am not ready to cut the square bars like you did, but it's a good idea down the road maybe. I hope to have these up and working within a week.
Avanti
Stoughton, Wisconsin
« Reply #13 on: September 03, 2017, 10:35:31 PM »
Made my own several years back. I am only 5'-10" so do not need as far forward as you may. i have located the control levers just to fit me. Both brake pedal and shift lever have a height adjustment and shift lever gets rid of the long gearshift arm. I use them all the time.
https://0-t.imgbox.com/NokkCONL.jpg
https://8-t.imgbox.com/FN3mSE58.jpg
« Last Edit: September 03, 2017, 10:46:21 PM by Avanti » Logged
« Reply #14 on: September 04, 2017, 02:39:48 AM »
Looks good... good fabricator + custom fit beats the
looks of one-size-fits-all...
« Reply #15 on: September 04, 2017, 05:47:47 AM »
cant wait to see how you do the fitting Harry
Ive seen Hubcap's and if you spend lots of time on your highway pegs they may be the ticket to long rides
Personally I spend most of my highway time on the mickopegs as they really take the stress off of my lower back and hips
« Reply #16 on: September 04, 2017, 08:19:19 PM »
I have installed them on both of my main riders.   I use them constantly; after I had them in their final config they have needed no additional adjustment. I ride with my feet on the fwd pegs much more than I do on the OEM pegs.  I'd guess DWBD was in over his head trying to install them. They might be best installed by a fabricator or serious gearhead with fab ability - in my opinion the BBT fwd controls are not plug n play - they will need more setup than some such as DWBD expect. If it was my product it would have changes such as what I added, with good documentation - and perhaps a recommend to have it installed by a pro.  That might hurt it's marketability.  There are a lot of issues involved in developing and marketing products for the public and you can't please everybody - there will always be complainers.  And with the advent of the internet, such unsatisfiable people can really hurt a product and it's selling company.  I'd say STFU and give BBT a break.  He has already gotten fed up and stopped production of the product and I don't blame him.
I modified both of my BBT fwd controls to improve their functionality by adding heim joints on both sides and replaced the brake pull bar with a straight tube so it wouldn't flex. If you still need pics I can shoot some and post them.  Be specific what you want.  I'll stick some below.  Meanwhile you can watch my video on youtube here: https://www.youtube.com/watch?v=ltgVugCRfFg
On Jade:
« Last Edit: September 04, 2017, 08:30:22 PM by MarkT » Logged
DeathWishBikerDude
« Reply #17 on: September 04, 2017, 08:46:05 PM »
Glad he's not making junk anymore. cooldude
