February 13, 2026, 06:44:14 PM *
Author Topic: Bleed Front Brakes  (Read 1469 times)
rugguy
2000 Valk I/S
Atlanta, GA
« on: September 04, 2017, 11:21:19 AM »
I have read a few threads and the Clymer Manual regarding bleeding the  brake lines on my I/S. All I managed to do is confuse myself. If I didn't disconnect any of the rear brakes lines I don't have to bleed the back lines right? I took the front forks off for service (don't ask) so all I should have to do is bleed the front right?
I hate asking something so simple but I am tired and may have had a beer.
Thanks in advance for you help.
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
DeathWishBikerDude
« Reply #1 on: September 04, 2017, 11:32:28 AM »
As long as nobody topped off the fluid you'll be fine.
« Reply #2 on: September 04, 2017, 11:39:35 AM »
You shouldn't have to disconnect any brake lines to remove the forks.  Why would you be having to bleed the brakes because of removing the forks?
« Reply #3 on: September 04, 2017, 11:43:36 AM »
If you just removed the calipers and did so without opening or removing the lines going to them, there should be no need to bleed them. Essentially, if you didn't open the lines then you haven't introduced any air into them. The calipers only have to be dismounted to remove the forks, they don't have to be disconnected.
I see Chris beat me by a couple minutes with the same analogy.  cooldude
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #4 on: September 04, 2017, 12:46:03 PM »
Had to remove the forks and trees for additional repair. Got a bleeder kit and things work great now. Thanks
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
« Reply #5 on: September 04, 2017, 02:48:39 PM »
For future reference and the point we were trying to make is that all you had to do was dismount the calipers from the forks and leave the hydraulic lines intact. No mess, no bleeding.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #6 on: September 05, 2017, 06:52:43 AM »
Thanks for that Chrisj CMA....but I also had a frozen caliper piston so I had to remove the caliper for service. Otherwise, I would never disconnect the caliper from the brake line....but for those who do have to disconnect, I HIGHLY recommitted buying vacuum brake bleeder kit. The best thirty dollars I have ever spent.
Thanks again.
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
« Reply #7 on: September 05, 2017, 09:35:47 AM »
Thanks again.
Well then, that's very different.  Must have missed the part about the caliper.
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #8 on: September 05, 2017, 11:15:34 AM »
Nah, you didn't miss it. I should have put that in the post.
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
