February 13, 2026, 06:43:46 PM *
Author Topic: Connecting battery tender to SAE or alligator clips?  (Read 1288 times)
MBritton
« on: September 08, 2017, 02:11:50 PM »
I have a battery tender that has alligator clips and the cable also has an SAE connection. Can I plug this into the SAE accessory port or do I have to use the alligator clips when charging the battery?
« Reply #1 on: September 08, 2017, 02:28:58 PM »
I attached my SAE pigtail to the battery and zip-tie that down near a rear footpeg.
Then I just plug in when done riding (24 X 7 X 365 when not out on the road).
The same SAE connection can be used for heated gear (though most modern stuff now used coax plugs, so you use a short converter wire) or my tire pump.
The alligator clips would require pulling the seat and battery cover...... every time.
« Last Edit: September 08, 2017, 02:30:36 PM by Jess from VA » Logged
Gideon
Indianapolis, IN.
« Reply #2 on: September 08, 2017, 04:34:38 PM »
That's the way to do it.  cooldude
MBritton
« Reply #3 on: September 08, 2017, 10:12:49 PM »
Thanks guys. Wasn't sure if I would damage something sending a charge back to the battery that way.
« Reply #4 on: September 09, 2017, 07:12:04 AM »
I have a Gerbing coax plug for heated gear that pokes out bottom rt fwd corner of the seat on Deerslayer, Jade, BluByYou, George, and the Magna.  Added the matching plug on 2 of my chargers.   Always bring the 6amp digital charger on trips.  Been too many times the battery has been dead so now that's required kit. Also handy if I want to run the bike stereo for entertainment at the motel while spinning Markaritas.
« Last Edit: September 09, 2017, 07:15:26 AM by MarkT » Logged
