February 13, 2026, 06:43:48 PM *
Author Topic: 12v Power plug problem.. Accidentally posted on the 1800 page!  (Read 1176 times)
BradValk48237
Oak Park, MI
« on: September 09, 2017, 09:04:55 AM »
OK.... Here the deal
Had a 12v power plug run direct from the battery..... used it for several years..
Last week on a trip It was not working and when I looked inside there was a ton of corrosion.. I lost the rubber cap a while ago....
So when we stopped for the night, I ran down to OReillys and grabbed a new one, had butt joint splices/crimps, so I snipped off the old one and crimped on the new one.... also bought a 12v USB  adapter the same as I had been using for years......
First problem was when I accidentally touched the metal lip of the socket to the handlebars it popped the breaker... so I secured it and replaced the fuse... no problem then. Until I plugged is the new 12v/USB adapter.... SIZZLE!!! POP!!! the damn thing was smoking!!! I had upped the fuse to a 20 amp.. but it still shouldn't have done that.....
SO I didn't F' with it the rest of the trip...... but got to thinking maybe it was a polarity issue....
SO today I finally got around to playing with it and switched the wires around..... Plugged in a NEW 12v USB adapter and...
SIZZLE!! POP!!!! Smoke and sparks!!!! SON OF A BITCH!!!!
Like I said, have been using the same setup for years no problem..... The plug socket i got is NOT for a cigarette lighter..says so right on the cap.
SO Im thinkin' its a bad plug socket, but before I go out and get a new one, looking for opinions/ideas....
B
« Reply #1 on: September 09, 2017, 09:23:07 AM »
Take it back and get another one. You have a bad plug.
« Reply #2 on: September 09, 2017, 10:00:00 AM »
SIZZLE POP SMOKE AND SPARKS!?????  You have a fuse problem too. Should blow the fuse immediately if you have a short, none of that drama.
BradValk48237
Oak Park, MI
« Reply #3 on: September 09, 2017, 10:29:29 AM »
Would take it back.... if I hadn't cut the cord.
Mark not a fuse problem as all I had was a 30 amp. Lol.
Steel cowboy
Spring Hill, Fl.
« Reply #4 on: September 10, 2017, 04:21:01 AM »
I had a similar issue on my sabre and that turned out to be the polarized plug going to the battery. I spliced it backwards. On the plug coming from the battery terminals The positive side should be the female part, of the connector.
2001 black interstate
2003 Jupiter Orange wing
BradValk48237
Oak Park, MI
« Reply #5 on: September 10, 2017, 12:39:50 PM »
Fixed. New plug and no problem.
But as I was cleaning up I found 2 spare 12 plugs in my "extras".  Coulda saved $20. Lol
B
