February 13, 2026, 06:42:48 PM *
Author Topic: New rear tire and brakes  (Read 1225 times)
« on: September 10, 2017, 03:22:28 PM »
So while watching the outer bands of hurricane Irma go by I decided to change out rear tire and brakes.
I could have safely got a couple thousand more miles but I was well over 20,000 on that tire and the brakes were thin so what the heck.
Was able to test the new tool.. I made a new solid bar to raise the swing arm
The better center to center hole to hole for stock pipes is 10 3/4"
Was very happy to see perfect splines still and drive shaft and pinion cup all nice and greased with pristine teeth.
No pictures but for a hurricane day we did ride to church before the stiff gusts started.  Now all new in the rear again  cooldude
« Last Edit: September 10, 2017, 03:29:16 PM by Chrisj CMA » Logged
Ken Tarver
North Mississippi
« Reply #1 on: September 10, 2017, 05:25:47 PM »
New tire / tires and brakes feel so good....no other comment  angel
Ken
Harryc
Sebastian, Fl
« Reply #2 on: September 11, 2017, 05:56:48 PM »
Hey Chris, I am guessing this is on an Interstate? Would the center to center hole be different for a Tourer?
« Reply #3 on: September 11, 2017, 06:15:03 PM »
Actually it was/is a standard but I think hole to hole 10 3/4 works on all bikes with OEM pipes
Harryc
Sebastian, Fl
« Reply #4 on: September 11, 2017, 06:21:54 PM »
Great, thanks. I think I am going to make one. I'd guess 1/8 x 1 flat steel stock would be good?
« Last Edit: September 11, 2017, 06:32:18 PM by Harryc » Logged
« Reply #5 on: September 11, 2017, 06:36:09 PM »
Sounds perfect. The lower hole that the shock bolt goes through has to be near the end with corners rounded to be able to angle to the upper stud
Harryc
Sebastian, Fl
« Reply #6 on: September 11, 2017, 06:38:43 PM »
Thanks again.
