February 13, 2026, 04:06:54 PM
front brake lever
Topic: front brake lever (Read 1177 times)
N0tac0p
front brake lever
September 11, 2017, 12:12:22 PM »
when I pull on it, I get a "chatter" feel, like the rubber plunger is sticky. seems like I have to pull it hard to activate the brakes. I rebuilt the fronts 2 years ago so I don't think its a caliper thing. but hey lot of wisdom here why not get feedback.
anyone?
SCain
Rio Rancho, NM
Re: front brake lever
September 11, 2017, 12:39:43 PM »
Sounds like the master cylinder. I would attach a hose to one of the caliper bleeder valves, open it up slightly just like you are bleeding the brakes and then see if you can pull the lever. If you can pull the lever with the bleeder open, its probably the calipers, if you can't pull the lever in with the bleeder open, its probably the master.
Good luck.
Steve
September 11, 2017, 12:52:36 PM »
Mine did that chatter. I removed the lever and noticed that the curved foot that actuates the M/C wasn't smooth. A little Emory cloth and all wrs greatly improved
Hooter
S.W. Michigan
September 11, 2017, 02:01:50 PM »
What Chris said happened to me. Might just bleed them any way see if it helps. Start simple.
longrider
Vernon, B.C. Canada
September 11, 2017, 03:18:53 PM »
And clean and grease the pivot bushing
Ken Tarver
North Mississippi
September 11, 2017, 03:26:04 PM »
Clean and grease pivot bushing will work for a little while...will need to replace
Ken
N0tac0p
Reply #6 on:
September 18, 2017, 02:32:59 AM »
just gotta say thanks to all who replied. whatever may have been creating the chatter in the lever, it was fixed via cleaning the plunger / lever contact point. whew, simple fix
