February 13, 2026, 07:24:50 PM *
Author Topic: Whine while stopped  (Read 1966 times)
Rocketman
Seabrook, Texas
« on: September 19, 2017, 01:59:26 PM »
Over the last two days, my '00 I/S has started to emit a loud, high pitched whine in certain circumstances.  My ride home from work is 7 miles, and it doesn't start until I pull into my driveway.  The first time it happened, I thought it was the radio or my helmet speakers giving some electronic noise, but it started as soon as I shut off the engine (kill switch, left the radio on).  It didn't happen this morning on the ride in, but it happened again on the way home.  Started as I pulled into the driveway, continued even as I was at a complete stop in the garage.  I put it in neutral to get off and do a walkaround to try to locate it.  On a hunch, I revved the engine a little.  It went away and didn't return.
I ride to work almost every day, this has never happened before this week.  Any ideas?  I'm worried that it's my timing belt telling me that it's reaching its end of life, but don't want to park it until I can dig in there if I don't have to.
Mark
« Reply #1 on: September 19, 2017, 02:38:05 PM »
Do you have LED headlights with fans on the bulbs?
Pete
« Reply #2 on: September 19, 2017, 03:46:31 PM »
Vacuum leak?
Pair Valve?
« Last Edit: September 19, 2017, 03:48:47 PM by Pete » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #3 on: September 19, 2017, 05:34:39 PM »
Vocal neighbor?
JimC
SE Wisconsin
« Reply #4 on: September 19, 2017, 05:59:51 PM »
Vacuum leak would be my guess also.
Actually after re-reading your post, it seems that it does it after the motor is shut off?
If that is the case it could not be timing belts.
Possible radiator leak?
Jim
« Last Edit: September 19, 2017, 06:02:26 PM by JimC » Logged
Jim Callaghan    SE Wisconsin
Firefighter
Harlingen, Texas
« Reply #5 on: September 19, 2017, 06:11:15 PM »
One time I rode from Harlingen to San Antonio (4.5 hour), and when I slowed down in town I could hear a whine, seemed to go away at times. I convinced myself that my timing belts were going to break or the bearings were gone in the pulleys, worried the entire time I was there, then rode home with no noise, ordered the belts and changed them. The old belts looked brand new, one of the pulleys had a small amount of rubber on it that I cleaned off, never heard the noise again or knew what it was. 2000 IS
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #6 on: September 19, 2017, 06:18:15 PM »
Vocal neighbor?
2funny
Rocketman
Seabrook, Texas
« Reply #7 on: September 21, 2017, 01:38:49 PM »
No, I don't.
Vacuum leak?
Pair Valve?
Could be.  I'll try to locate it better next time it happens.  A vacuum leak seems unlikely to make that horrendous high pitched whine, but it's possible I suppose.
Jim
It does not keep going after the engine is shut off, although this is a very small data set.  Once it stopped when I shut off the engine, and the other time it stopped when I revved the engine.
Yes, she's noisy, but she wasn't home at the time.
« Last Edit: September 21, 2017, 01:41:26 PM by Rocketman » Logged
Rocketman
Seabrook, Texas
« Reply #8 on: September 21, 2017, 01:40:39 PM »
Update:  It didn't happen today.  I don't know if the cooler weather affected it (if it's radiator/fan related) or the light drizzle, or it just plain went away like Firefighter's did.  I also don't know if it will reoccur tomorrow.  I'll holler if it does.
da prez
Wilmot Wi
« Reply #9 on: September 21, 2017, 03:05:54 PM »
  Stop for a beer (or ice cream) before going home. If it stops whining , well , you figure it our.
    ( THIS IS INTENDED TO BE A JOKE)
                                            da prerz
Steel cowboy
Spring Hill, Fl.
« Reply #10 on: September 22, 2017, 11:23:21 AM »
Alternator bearing ??
2001 black interstate
2003 Jupiter Orange wing
« Reply #11 on: September 22, 2017, 11:49:12 AM »
You've started giving my ex passenger rides?
DeathWishBikerDude
« Reply #12 on: September 22, 2017, 04:19:39 PM »
Change the oil recently?
Certain oil protect better and keep the engine whine down,but doesn't eliminate it.I like my whine..lol
Rocketman
Seabrook, Texas
« Reply #13 on: September 23, 2017, 07:00:07 PM »
To be clear, this is not normal engine wine.  It started abruptly.  It's significantly louder than anything I've heard from Valkyries before.
Rocketman
Seabrook, Texas
« Reply #14 on: October 07, 2017, 04:36:57 PM »
I did a walkaround once, listening closely.  I didn't have a screwdriver or anything to truly locate the sound, so I could only get general location.  It's not an alternator bearing, it's coming from the center or front of the engine.  Could be in the timing belt area, but more likely pair valve.  I'll locate it more closely if it ever happens again when I can listen.  Seems like it happens only when I roll in to work at O-dark-thirty and I'm in a rush, or while I'm at a stoplight and getting off and putting my ear up to the engine would get some funny looks, to say the least.
Mark
WintrSol
Florissant, MO
« Reply #15 on: October 07, 2017, 06:52:12 PM »
Keep a length of fuel tubing handy, to use as a stethoscope. If you put a screw or bolt in one end, you can use it to locate the source more accurately. A roll a few feet long should fit in a jacket pocket, so you don't even need saddle bags.
Firefight100
USA
« Reply #16 on: October 08, 2017, 07:34:04 AM »
Check the radiator cap.  It sounds like pressure going out the cap.  Happens after a ride, when you are going slow and continues after you shut off.  Next time you hear it, loosen the cap to the first notch.  Be careful for hot fluids.
https://PrivateLadyEscorts.com - Meet Local Private Lady Chat - No Verify - Anonymous Adult Dating -   Webcam Chat Dating
