February 13, 2026, 04:06:26 PM *
Author Topic: Rear Rotors  (Read 1811 times)
jbrooks
Oliver British Columbia
« on: September 23, 2017, 08:40:34 PM »
Does anyone know if a rear rotor from a 98 tourer is compatible with a 2000 interstate.
Nevermind I found the old post that clarifies this
« Last Edit: September 23, 2017, 08:58:26 PM by jbrooks » Logged
Jack B
Two Rivers Wis
« Reply #1 on: September 24, 2017, 05:20:49 AM »
I have a rotor that will fit a 99 Interstate if you need one. It is like new.
Let’s RIDE
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: September 24, 2017, 06:12:55 AM »
The quick answer is no.
1997 to ~mid 1999 Std and Tourers use the early style rear rotor that goes with the early rear wheels that have '1J' in the rotor recess on the left side of the rear wheel.
~Mid 1999 to 2003 Stds and Toures and all Interstates use the later rear rotor that goes with the later rear wheels that have '2J' in the rotor recess on the left side of the rear wheel.
This is assuming that both bikes have the original wheels that have not been changed.
Note: As for the front rotors, they are all interchangeable from 97-03. The early front wheel (97) has a '1J', the later (98-03) front wheels have a '2J'. Difference is in front bearing size.
« Last Edit: September 24, 2017, 06:19:31 AM by indybobm » Logged
So many roads, so little time
VRCC # 5258
Blackduck
West Australia
« Reply #3 on: September 24, 2017, 07:11:10 AM »
As per the pic in the previous post, late ones have the countersunk screw heads. The early ones are not countersunk
Have a 2001 STD and use an early rim as my spare. Have never checked if the disc's will interchange using the right retaining bolts. they are both still in good shape.
indybobm
« Reply #4 on: September 24, 2017, 08:04:30 AM »
Blackduck, they will not intgerchange. There is an offset built in to the rotor that keeps it from interchanging no matter which screw you use.
VRCC # 5258
Blackduck
West Australia
« Reply #5 on: September 24, 2017, 04:36:15 PM »
I know they are offset on the rim, just had not checked where the offset is.
I space the caliper when changing the rims to keep it central on the disc.
Cheers Steve
