August 24, 2025, 09:36:11 AM
Clutch Banjo bolts leaking
Topic: Clutch Banjo bolts leaking (Read 1191 times)
RUDE DOG - Steelers
New Jersey - VRCC # 3966
September 25, 2017, 06:11:24 PM »
Okay so I got the clutch slave all put back together. I went and put some fluid in the reservoir to bleed the clutch. Within a couple minutes before I even tried to bleed it, there are leaks coming from the banjo bolts where the connect to the clutch slave. Never leaked there before. Lines are fairly new only 2 years old. Any suggestions?
Firefighter
Harlingen, Texas
Re: Clutch Banjo bolts leaking
September 25, 2017, 06:24:08 PM »
Your supposed to replace the seal washers, 2 for each connection.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Bronson
Belvidere, IL.
September 25, 2017, 06:26:00 PM »
You may need to reassemble the banjo bolts with new crush washers, they are little copper washers that are supplied with the banjo bolts. The old ones usually leak if you try to reuse them. Otherwise crud on the mating surfaces, or a nicked surface may be to blame...
Just some thoughts on possible causes.
Bronson
RUDE DOG - Steelers
September 25, 2017, 07:04:06 PM »
Thought I could just reuse them. Can they be had at local auto parts store?
WintrSol
Florissant, MO
September 25, 2017, 07:16:15 PM »
If you can't find new ones, the old ones can be annealed (softened) to remove the work hardening, and they should seal again. If you heat them with a gas flame until they glow red, then let them slowly cool, that should do the trick. Keep looking for replacements, though, as it doesn't always work out.
da prez
Wilmot Wi
September 25, 2017, 08:06:30 PM »
Banjo bolt copper seals on a G M front disc brake. I have about a hundred of them.
da prez
DeathWishBikerDude
Reply #6 on:
September 25, 2017, 08:54:06 PM »
Pretty common item,one time use only.
RUDE DOG - Steelers
Reply #7 on:
September 25, 2017, 09:03:12 PM »
Thanks Guys, will look for these tomorrow.
Reply #8 on:
September 26, 2017, 06:56:36 AM »
Quote from: RUDE DOG - Steelers on September 25, 2017, 09:03:12 PM
I've always only found them locally (Advance or whatever) in little
combo packs, where you have to buy a handful of different
sized ones, but there's always been two in there the right size...
=> InZane XXV
