February 13, 2026, 04:07:02 PM *
Author Topic: Header Pipe Nuts - why no lockwasher?  (Read 1508 times)
Glaserbeam
Southern California
« on: September 25, 2017, 07:01:04 PM »
I replaced my exhaust system, installed new gaskets where the pipes meet the exhaust ports, and tightened the acorn nuts, but 1,000 miles later some of the nuts were loose and one was missing ... I snugged them up again (just as tight as they were with the original exhaust system) and a couple weeks later they were loose again.  This is frustrating since the nuts shouldn't be vibrating loose, and I don't want to overtighten anything and crush the gaskets or break a stud.  Why aren't lockwashers used with the acorn nuts?  Would it hurt anything to add them?
Still lovin' the Valk!
Ken
« Reply #1 on: September 25, 2017, 07:18:43 PM »
With new gaskets, and a light 7 foot (or is it inch) pound torque setting for the header nuts, it is SOP to snug those nuts on install, and then at least twice more, after riding and heating them up.  Each time, compressing the gaskets more.   If you try to do it all at once, you'll likely snap a stud or two.
Using quarter inch sockets not only are easier to fit into tight spots, but also give a better feel when torquing (I don't use a torque wrench, just by feel).
I lost two acorns, and doubled up two standard nuts in replacement (both hidden unless under the bike).  I snugged the first, then used the second like a lock nut.  Anti seize is probably a good idea too.
« Last Edit: September 25, 2017, 07:20:25 PM by Jess from VA » Logged
« Reply #2 on: September 25, 2017, 07:55:39 PM »
You waited 1000 miles to do the initial re-tightening, then two weeks for the next.
That is too long,  no wonder nuts were lost.
Once you get the gaskets squished down they won't loosen up any more.
« Reply #3 on: September 26, 2017, 07:56:05 AM »
I recommend tightening them twice, a week or so apart, and check again.  You can use loctite 242 (blue) to increase friction so they won't walk off.  But you'll still need to tighten them.  I too use 1/4" sockets.  On nuts 12mm & smaller.  Get a 10mm swivel socket for the header nuts.  Wobble drive extensions are also useful. On #5 cylinder back nut have to use 12 pnt box end. I keep one with the wall ground thin to fit.
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #4 on: September 26, 2017, 08:53:24 AM »
They're crush washers, you're supposed to crush them.
« Reply #5 on: September 26, 2017, 10:37:39 AM »
I missed that lol. No wonder, trying not to crush them....
The sooner they get completely crushed the sooner the nuts will stay tight.
da prez
Wilmot Wi
« Reply #6 on: September 27, 2017, 06:40:55 AM »
  Back to the original question. Lock washers on an exhaust system will rust off. This goes back to the days of installing brass nuts on the exhaust pipes at the headers to be able to get them off. Flat washers were used to prevent the problem. A flat washer will allow the nut to slide (reduce friction) as it is tightened. The lock washer would let water in a lot easier , and rust off.
                          TA  DAH
                                                          da prez
h13man
Indiana NW Central Flatlands
« Reply #7 on: September 27, 2017, 07:06:50 AM »
Anti-sieze and SS lock washers is an option and the re-torquing schedule as mention by others. As far as Loctite is concerned, I use heat to free Loctited fastners.
« Reply #8 on: September 28, 2017, 08:18:52 AM »
I haven't had acorns on my header pipes almost from the first day I got the bike. Often you'll find acorns aren't deep enough to allow full tightening, so I simply converted to plain nuts/washers and move on. Never have had a nut come loose since, and if the looks of plain nuts bothers someone then explain to me why you're standing on your head to look at my bike.  Grin
Oldnick
Western Australia
« Reply #9 on: September 29, 2017, 03:55:09 PM »
HAHAHAHA! As I read your post I was starting to think just the same thing!
Nick
Nick
May God save us from believers!
