December 16, 2025, 04:47:47 AM *
Author Topic: Progressive rear spring install  (Read 2557 times)
bscrive
Ottawa, Ontario
« on: October 01, 2017, 06:26:19 PM »
I got the Progressive spring that I ordered a little while ago and installed it last night.  The removal of the shock/spring from the bike was pretty straight forward.  I took off the pivot mechanism underneath the bike.  There were 3 bolts for that.  I then removed the two bolts that hold on the damper.  I then moved on to the top bolt.  I removed the stuff I needed to to lift up the back of the tank.  I could have removed the tank, but I just filled it and I didn't want to try to move it around.  I thought that I may have had to remove the tool box to get at the top nut, but then I decided to use a large straight screwdriver and jam it between the side of the bolt and the side of the wall.  The bolt is countersunk.  I used a 10mm Allen socket on an extension to loosen the bolt.   The shock came right out through the bottom.
I made my own tool to change the spring and it worked perfect.  Putting the new spring on and putting back the clip was another thing.  The clip fits into a sleeve that slides on the shock.  The damn thing kept siding down and I finally had to jam a homemade tool against it, so that it wouldn't move when I put the top piece back on.  After some cursing I finally got everything put back together.
Putting back on the bike was pretty uneventful.
I decided then to take the bike for a ride.  The spring worked pretty good.  Nothing earth shockingly awesome, but the jarring that I had before was pretty much gone.  I put the damper on the second click.  I will have to give this an 8 out of 10 for satisfaction.  It is definitely worth the time and money for me to do this.  Makes the bike a little more enjoyable to ride.  The spring only cost me $88, so it was a cheap investment with good return.
If you don't know what a progressive spring is, it is like our spring on our bike, but the last three coils are closer together to give you a little more plush ride when you are riding alone.  The one I got is made for the F6B or full wing.
http://www.ebay.com/itm/Progressive-Suspension-01-1179B-Rear-Springs-Kit-D-Honda-Goldwing-GL1800-/172195352069?epid=1011869115&hash=item2817a48e05:g:2gMAAOSwMgdX03GL&vxp=mtr
« Reply #1 on: October 03, 2017, 05:17:15 AM »
I looked at the pics of the spring you installed and its not only a Progressive spring but a progressive rate spring. Glad to know it worked well.
