February 13, 2026, 09:26:18 PM *
Author Topic: leaking clutch fluid  (Read 1170 times)
scarylarry
wis rapids, wi
« on: October 03, 2017, 11:21:56 PM »
It looks like I'm leaking clutch fluid from the back of the motor, where the clutch cable and bleeder are located.  There are 3 bolts and what looks like a weep hole, looks like its coming from 1 of those bolts.  I'm guessing there is a gasket behind there that needs replacing.  Anyone ever encounter this problem and know how to fix it?  I appreciate any advice..thanks in advance
« Reply #1 on: October 04, 2017, 02:52:31 AM »
By your description, your talking about the slave cylinder.
It's been a while since I had a slave off but I don't believe there is a gasket between the slave and the case.
The leak is most likely either from the banjo bolt #12 or the interior seal of the slave #15
Clean the area real good and watch for new leaking.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1999/GL1500CF+A/CLUTCH+COVER/parts.html
Firefighter
Harlingen, Texas
« Reply #2 on: October 04, 2017, 04:21:36 AM »
I did mine a while back as it was leaking like you describe and I replaced # 6,7,9,14, 15 and two of the # 13 bango bolt seals. Have to loosen the kickstand and swing to the side to get all three bolts out that hold the slave on, so will need a jack or wheel chock to hold the bike upright.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
