February 13, 2026, 07:25:52 PM *
Author Topic: kickstand..any tips  (Read 1208 times)
scarylarry
wis rapids, wi
« on: October 07, 2017, 08:31:55 PM »
Anyone out there have any tips for getting those kickstand bolts off?
Carl
Friendswood, Tx
« Reply #1 on: October 07, 2017, 10:56:56 PM »
I ended up having to use an impact.  I have a fairly compact one I use with an air compressor.   I also have an 18v impact that I suspect would have done the job. It is not very small and I would have had to lift the bike inorder to get it underneath.  Maybe a friend has one you can borrow.
scarylarry
wis rapids, wi
« Reply #2 on: October 08, 2017, 01:20:22 AM »
I ended up borrowing a friends 24" breaker bar.  Still a pain holding the bolt on top by myself but got it done.
« Reply #3 on: October 09, 2017, 07:11:02 AM »
why you removing the kickstand entire assembly?
If not going to use the parts on it, I need the spring and bolt underneath.
Jonesz
Manitoba, Canada
« Reply #4 on: October 09, 2017, 01:25:05 PM »
Honda parts nation have those two things. Will set you back about $13
http://www.hondapartsnation.com/oemparts/a/hon/506cb697f870023420a418d2/side-stand
Fazer
« Reply #5 on: October 09, 2017, 01:36:44 PM »
I had to loosen the bolts to add the jack adapted and as I recall used a 1/2" ratchet with a cheater pipe and held the head on top with a box wrench that spun around and hit something solid enough that I could loosen the nut.  I think I gave them a good shot of penetrating oil first.
Nothing in moderation...
