March 14, 2026, 10:11:21 AM
Texas Chapter
(Moderator:
Daniel Meyer
Identifying what's wrong
Topic: Identifying what's wrong (Read 2248 times)
RainMaker
Arlington, TX
October 09, 2017, 04:09:27 PM »
The Tourer developed a new sound today. Thought it was exhaust or vacuum lines but no luck so far. If you can listen to this clip and identify the problem, I'd be most appreciative.
RainMaker
https://www.youtube.com/watch?v=So_wMA_v6kU
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
BnB Tom
Where'd old times go?
Frisco, TX
Re: Identifying what's wrong
October 10, 2017, 06:13:11 AM »
Does it go away when you pull in the clutch or shift into gear?
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
October 10, 2017, 06:36:17 AM »
Difficult to say just listening to a sound clip but to me sounds like an exhaust leak. Where is it coming from? Have you tried to localize the sound using a ruler or dowel pushed up against the engine, kinda like using a stethoscope?
SideCar
Bikers don't need shrinks!
Colleyville, TX
October 10, 2017, 07:26:10 AM »
+1 on exhaust leak. While it could be a valve, that is less likely to be acute onset at that loudness.
Come Ride to Save a Child's Life
http://www.curethekids.org/rideforkids/
RainMaker
Arlington, TX
October 10, 2017, 09:48:21 AM »
We've checked the timing belts to make sure one didn't slip and screw up the valves. Found a missing bolt on an exhaust manifold so guessing that is the problem. Thanks for the ideas!
2005 BMW R1200 GS
1972 CB500K1
franco6
Houston, TX
October 13, 2017, 07:07:56 PM »
Exhaust leak ,major one ,striped header bolt Hope it s not the head thread
or ___
Enjoy the ride!
