February 13, 2026, 07:24:54 PM
goldwing floor boards on Valkyrie
Topic: goldwing floor boards on Valkyrie (Read 1200 times)
firemedic309
Sarasota. FL....Nancy Ky
October 14, 2017, 09:16:56 AM »
will floorboards off a 1500 wing fit on a 97 tourer? thanks
Remember, if they can't find you handsome at least they can find you handy!
Re: goldwing floor boards on Valkyrie
October 14, 2017, 10:09:20 AM »
Which, front or back?
Either one, the answer is yes.
Which kind do you have, the one for the front can have the 3 point mounts, they work.
Or the one where you remove the peg and replace with the board? I haven't done this one, but no reason why it shouldn't.
Rear boards, I moved from my Shadow to my Valk, back to the Shadow and then a GW, and again have on my IS. They where an aftermarket clone, I think to the Cobra, made of aluminum (the post), and all I needed to do was ream out the mounting hole a little to get the pin through.
firemedic309
October 15, 2017, 10:56:37 AM »
Thanks saw some fronts listed on craigslist, if the dude gets back with me I would like to put a eye ball on them.
