August 24, 2025, 02:02:27 AM *
Author Topic: Did my petcock fail?  (Read 1257 times)
Davemn
Minnetrista, Minnesota
« on: October 18, 2017, 05:30:34 PM »
I rebuilt my stock petcock a few years ago. Today I put 5.0 gallons of gas in. The "selector was "ON"......not "Reserve".  I have had a feeling that the reserve hasn't been working. Is it possible to do something wrong rebuilding with a cover set? Maybe a Pingle is in my future.
« Reply #1 on: October 18, 2017, 05:35:03 PM »
I suppose you can rebuild one wrong, but more likely it has simply failed again.
Both my OEs have been rebuilt..... and I have two more coversets in waiting.
« Reply #2 on: October 18, 2017, 05:46:17 PM »
I have two Valkyries, both have Pingel fuel valves.  So nice to have no worries about fuel starvation petcock related anyway.
« Last Edit: October 19, 2017, 06:21:55 PM by Chrisj CMA » Logged
Jruby38
Oxford Mass.
« Reply #3 on: October 19, 2017, 12:28:49 PM »
Ditch the POS OEM. Buy a Pingle. 15 years, not a problem.
Harryc
Sebastian, Fl
« Reply #4 on: October 19, 2017, 02:18:05 PM »
Ditto ...
Cracker Jack
« Reply #5 on: October 19, 2017, 02:34:27 PM »
OEM, 17 years without a problem. cooldude
Glaserbeam
Southern California
« Reply #6 on: October 19, 2017, 08:22:19 PM »
The same thing just happened to me.  First, it dipped into the reserve without me switching to reserve (I thought my fuel economy has magically improved because I was still on Main 20 miles past the usual switching point), then a few weeks later it started leaking.  Rebuild kits don't address either issue.  I replaced it today with this one, which seems nearly identical to stock - the vacuum feature works - at half the price:
https://www.ebay.com/itm/Honda-GL1500-C-CD-CY-Valkyrie-1997-2003-Fuel-Petcock-Gas-Tank-Valve-K-L-18-4161/142418029821?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Ken
DeathWishBikerDude
« Reply #7 on: October 20, 2017, 04:13:04 AM »
Pinged on both my rides.
Kunkies
Charlotte, NC
« Reply #8 on: October 20, 2017, 04:33:37 AM »
Pinged as well. . . suggest:  1311-CHV (with vacuum control), or 1311-CH (without)
h13man
Indiana NW Central Flatlands
« Reply #9 on: October 20, 2017, 04:43:52 AM »
Pingle here also but I reset the odometer to keep track of that 160 mi. mark that tells me to look for fuel. Old habit from a very long time ago.
jrram77389
« Reply #10 on: October 20, 2017, 06:18:46 AM »
When installing a pingel or there any adjustments that need to be made to the carburators?
« Reply #11 on: October 20, 2017, 06:22:34 AM »
You might have to adjust your "always turn it off" memory, and you'll have to adjust
your reserve expectations, but not your carburetors...
George B
Marion Illinois
« Reply #12 on: October 20, 2017, 07:06:36 AM »
I picked up one of these, too. My new to me Tourer had 60 k on it and a kinked vent tube. Out of curiosity I took the OEM apart when I had the tank off and the diaphragm was in pretty sad shape. I will rebuild the old valve and put it on the shelf for future.  I didn't have a reserve issue, so I can swap it out in a few years.
1997 1500CT with California Sidecar
Now a Roadsmith Trike conversion
Former rides:
1988 BMW R100GS
2007 Ural Patrol
15 HDs from 1937 to 1977
« Reply #13 on: October 20, 2017, 07:44:22 AM »
The ON-OFF-RESERVE function has nothing to do with the vacuum side of the valve, and a rebuild kit (cover set) will do nothing to fix a valve that allows fuel from the reserve part of the tank to flow when the valve is on the ON position.
