February 13, 2026, 09:26:12 PM *
Author Topic: 1999 Interstate Headlight adjust  (Read 1985 times)
HBFL
« on: October 20, 2017, 06:58:13 PM »
Forgive me in advance, I did no searches, I just want to lower my headlight beam. What direction do I turn the vertical adjuster to lower the beam. Also what direction for the horizontal adjustment narrows or expands the beam. Still happy I have this 99 over my 08 Goldwing. Thanks.
« Reply #1 on: October 20, 2017, 10:14:01 PM »
I don't know, never touched it, but I would suspect that the Service Manual should have that info. Do you have a copy yet?
PDF can be had here,
http://www.valkyrienorway.com/download.html
The Valkyrie doesn't have the same kind of quick beam adjustment that the GW had. No air shock to increase/decrease, or the extra weight of a passenger on the back, to change the aim of the head light, then a little turn of the aim dial.
The beam can't be adjusted. Only those 2 dial on the back of the lights to correct the aim. I don't ride nights, so I don't even know where mine are aimed.
« Reply #2 on: October 21, 2017, 06:44:20 AM »
never had to touch mine sorry no help.  I know my 98 Valk std./tourer single headlight is not nearly as bright or wide of beam as my dual beam I/S at night for sure.
I always thought the I/S headlights were pretty darn bright at night, especially the brights even OEM since when on at night, the brights seem to shine WAY up to read the billboards/road signs way up high very, very bright/clear.  My std. valk not so much.
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #3 on: October 21, 2017, 06:51:15 AM »
HBFL, you'll find more people willing to help those that at least attempt to help themselves first, a simple board search came up with this;
http://www.valkyrieforum.com/bbs/index.php?topic=45177.0
I've used this method since I aimed headlights on my first car, I park facing a wall and turn the screw and observe which way the light is moving.   cooldude
HBFL
« Reply #4 on: October 21, 2017, 04:53:37 PM »
For the record clockwise raises the beam CC Lowers it on the vertical adjusters. I had to lower mine a good bit so my high beam doesn’t hit the treetops. ESP with my sweet pillion. All good.
