February 13, 2026, 07:24:12 PM *
Author Topic: emgo microglass oil filter  (Read 1770 times)
scarylarry
wis rapids, wi
« on: October 27, 2017, 12:44:11 AM »
HI..I was considering ordering an emgo black microglass oil filter.  Looks like a good deal if its a good filter.  Anyone use 1 or know anything about the microglass filters?  Thanks in advance.
Ramie
2001 I/S St. Michael MN
« Reply #1 on: October 27, 2017, 05:32:26 AM »
To be honest I've never heard of them before but the name micro glass pulls up images in head of tiny particles of glass suspended in my oil and i cringe a little.
SCain
Rio Rancho, NM
« Reply #2 on: October 27, 2017, 08:52:48 AM »
Emgo has been around a looooong time making aftermarket parts, I don't think I have seen a study or an analysis done on their oil filters, can't be any worse than a Fram. There are lots of filters out there that I think I would use before using the emgo. Just my .02
Super Tech (Champion) or Puralator.
Steve
northernvalk
Sudbury, Ontario, Canada
« Reply #3 on: October 27, 2017, 09:35:33 AM »
I think the NAPA gold (wix) filters are the best all around iirc.  Fram is THE WORST, and I used to run them for a long time  Angry.  I should have done some research but I stick with wix now and will until something better is proven.  Isn't there some honda civic filters that we can use which are larger than ours but fit right up??????
Savago
Brentwood - CA
« Reply #4 on: October 27, 2017, 09:38:17 AM »
They make what is considered one of the best filters available for the Suzuki vstrom (i.e. 10-55660), so I'm pretty confident that it should work fine for a valkyrie.
But like others already mentioned, if you wanna the best, you should look for a Purolator Boss Premium:
https://www.amazon.com/gp/product/B01G6FPI1S/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
This one I posted is compatible with the honda ST1300, not sure about the Valkyrie.
« Last Edit: October 27, 2017, 09:42:43 AM by Savago » Logged
« Reply #5 on: October 27, 2017, 12:18:21 PM »
IMO,  hf303 from hi-flo at 8-9 bucks each is hard to beat.
Purolator always makes good filters as well.
If EMGO oil filters is anything like their aftermarket cheap EMGO mirrors for cycles, I will pass on them as well.
« Reply #6 on: October 27, 2017, 01:00:52 PM »
I use an oversized Purolator Pureone. Yes I have stash of the originals when it was still an American company.
an interesting read, however I have not seen filter testing for an IC engine.
http://machinerylubrication.com/Read/998/varnish-formation
Another cause of hot spots is the generation of spark discharges. The power generation industry's shift to synthetic and glass filter media has created unexpected side effects caused by the combination of tighter filter pore sizes to remove fine sediment with high filter flux rates (flow rate per unit area) to reduce capital cost. The result is static charge buildup within the oil system.
These spontaneous discharges (lasting nanoseconds) can generate sparks with temperatures greater than 10,000°C (more than 18,000°F), which is hotter than the surface of the sun. This intense heat caused by static discharges literally cooks the oil, creating oil molecule fragments that deplete antioxidant additives. A video of the filter spark discharge test conducted by Dr. Sasaki can be found at www.kleentek.com/video.asp.
Although filter manufacturers are conducting research to mitigate the static charge effect of synthetic and glass media, additional research has shown that places in the oil circuit where metal-on-metal contact occurs can also generate a significant static charge that leads to spark discharges.
Toovalks
East Lansing,Michigan
« Reply #7 on: October 27, 2017, 03:02:04 PM »
Vaquero...you are one incredible wealth of information.
Gideon
Indianapolis, IN.
« Reply #8 on: October 27, 2017, 03:16:53 PM »
I used EMGO Micro-Tech Filters for years. They are very good.
However, after joining this forum I heard about the PureOne PL14610 Filter. You can use all 4 qts. of oil, it works very well and is less expensive.  cooldude
« Reply #9 on: October 27, 2017, 04:15:03 PM »
thanks.  I've been called many things because of it, even Sheldon from the Big Bang Theory show and a walking tech manual. LOL
scarylarry
wis rapids, wi
« Reply #10 on: October 28, 2017, 01:49:17 PM »
Thanks for the info..I'll pony up a few more bucks and get a purolator boss or Honda oem
« Reply #11 on: October 28, 2017, 07:11:27 PM »
Unless mistaken, I looked up the WIX filter and is white part#  WL10000.  not fond of a white oil filter on a black cycle.
I looked up that purolator Pl14610 and also good to know since is 7 bucks at farm and fleet and those purolator one oil filters go 2-3 bucks off every now and again as well.  Plus,  is blue color to somewhat match my blue/ivory cream 98 Valkyrie.  Just do not like white oil filters.   Cheesy
« Last Edit: October 28, 2017, 08:09:39 PM by cookiedough » Logged
mello dude
Dayton Ohio
« Reply #12 on: October 29, 2017, 01:17:44 PM »
This info has been around a long time, but been using between the Purolator PL4610/12 or Bosch 3300/23 what ever on sale or convenient available at the auto parts store.
https://motorcycleinfo.calsci.com/FilterXRef.html
I'm not freaking out on whats the best filter... kinda like asking whats the best beer...
« Reply #13 on: October 29, 2017, 04:09:55 PM »
Molson Golden of course.  Wink
scarylarry
wis rapids, wi
« Reply #14 on: October 29, 2017, 04:54:23 PM »
I just happened to need to go to Wally World today, so I decided to look at their filters.  They have both the Mobil1 m1-108a and m1-110a (new part#) for the same price, $10.  I have a black bike so a black filter is a must.  I never buy oil filters from Walmart so I was unaware they sold Mobil1 filters.  A new m1-110a it is for me.
I was curious as to what plp had to say about micro glass since I had not heard of them before.
Thanks to all for the replies and information.
PS.  I have read that Mobil1 MC oil filters are made in China and not the same quality as the auto filters.
« Reply #15 on: October 29, 2017, 07:00:39 PM »
unless mistaken both hi-flo and k&n number that fits our Valks are KN303 or HF303 which is not the one listed in this link, very odd.
« Reply #16 on: October 29, 2017, 07:20:08 PM »
http://www.jkozloski.com/generic_parts.htm
northernvalk
« Reply #17 on: October 30, 2017, 10:17:30 AM »
WOW, coming from an american I must say, thanks! Golden was discontinued, then brought back as a lager instead of the original ale. Both are good, but the original was better imho
