November 15, 2025, 03:51:47 AM *
Author Topic: Recommendation of Driving Light Bracket  (Read 1008 times)
Jersey
VRCC #37540
Southern Maryland
« on: November 05, 2017, 12:20:52 PM »
Thought I'd make a recommendation on these brackets.
I use them to hold small driving spot lights.  It mounts very well on the front shocks, just a few inches below the fairing on the IS.  Would work equally well on the S/T models.  Just the right size to hold tightly without being too much to affect the shock
https://www.ebay.com/itm/Pair-of-Aluminum-Front-Turn-Signal-Mounts-for-Custom-Choppers-with-55mm-Forks-/292065078652?hash=item44006f6d7c
Jersey
Rosie
Clintonville WI 54929
« Reply #1 on: November 05, 2017, 12:47:31 PM »
Do you have a picture of these mounted on your bike that you could share?
1999 Valkyrie tourer
2003 Valkyrie standard
WintrSol
Florissant, MO
« Reply #2 on: November 05, 2017, 04:54:28 PM »
Interesting. Could maybe use them to mount dual horns, too.
h13man
Indiana NW Central Flatlands
« Reply #3 on: November 05, 2017, 09:50:13 PM »
I have a set of the black ones below in the ad but they were to small and need to be bored out to work. Ended up fitting mine on the engine guard using Kury 1 1/8 bar clamps as the Kury "P" mounts were to cheap/chinzy fitting for my taste.
Jersey
VRCC #37540
Southern Maryland
« Reply #4 on: November 06, 2017, 03:07:52 AM »
The front shocks to taper slightly in diameter, being thicker higher up.  That's why I recommended these to same others the trouble in figuring it out.  The 55mm seems to be the right size for mounting higher up the shocks.
Jersey
Bagger John - #3785
« Reply #5 on: November 06, 2017, 07:46:53 AM »
There were a couple of manufacturers who offered 55mm clamps over the years.
I have a set from the outfit which offered a hotrodded XR1200 Sportster back in the early 2000s. Wanting to say Storz Performance but I'd have to dig around through the stash to find the package.
Add-On/Big Bike Parts had a wind deflector set which used a similar clamp arrangement.
Itinifni
Boston
« Reply #6 on: November 06, 2017, 05:44:34 PM »
I used a pair of OEM front directional mounts to add lights to my from forks.
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
97 Valkyrie Std. (May surpass the GL1100 as the best bike I've ever owned, I'll update in 50k miles)
