January 30, 2026, 01:53:51 AM *
Author Topic: again pet rooster  (Read 1886 times)
franco6
Houston, TX
« on: October 26, 2009, 10:06:20 AM »
i ve seen picts of a complete take apart of the stupid thing,    can t find them now.it won t turn off or reserve while vac is applied.
as anyone done a complete rebuild, beside the diaphragm?what to look for ? did i see rivets ? Smiley
Enjoy the ride!
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: October 26, 2009, 10:24:21 AM »
Here you go.  http://www.valkyrieriders.com/shoptalk/petcock.htm
Marty
« Reply #2 on: October 26, 2009, 11:28:52 AM »
That's a good article, with a really good test at the end to keep you from putting everything back together only
to find out later that you did something wrong...
Here's some really good pictures:
http://valkyrie-owners.com/SMFORUM/index.php?topic=7055.0
« Reply #3 on: October 26, 2009, 12:57:16 PM »
install a snubber in the vac line and the diaphragm will not wear out for a long time.
Spirited-6
Nicholasville, Ky.
« Reply #4 on: October 26, 2009, 01:56:38 PM »
WHAT is a "SNUBBER" ?
Spirited-6
lee
Northeast Tennessee
« Reply #5 on: October 26, 2009, 04:57:55 PM »
Time is not what is taken but what remains.
C. Drewry
« Reply #6 on: October 26, 2009, 05:21:21 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,3408.0.html
lee
Northeast Tennessee
« Reply #7 on: October 26, 2009, 05:57:40 PM »
I= Fuel inlet from top of stand pipe.
J= Reserve fuel inlet.  When the sealing ball is over this port the valve is in the ON position.
K= Ball is in this position when valve is in the RESERVE position.
L= Fuel outlet from manual side of valve. When ball is over this port valve is in OFF position.
M= Spring loaded ball keeper.  When the valve is assembled the ball can not get out of this keeper.
N= Sealing ball.
THINGS THAT CAN CAUSE THE MANUAL SIDE OF VALVE TO MALFUNCTION.
1.Dirt in tank and valve cavity. (keeps ball from sealing port).
2.Rusty ball (pitted) caused by water standing in tank for long period.
3.Bad O-ring around port. ( I have heard of this, but I have never seen one with a bad O-ring).
4.MOST COMMON  (Operator Error) You can feel and hear the ball (spring loaded) fall or
            jump into the port when you switch the valve.  If you don't then you need to ride home
            and start looking for the siphon hose.
C. Drewry
franco6
Houston, TX
« Reply #8 on: October 26, 2009, 09:52:32 PM »
thanks LEE that s the picts i needed. it is the manual side that is giving me trouble .can you replace the rivets with nuts and bolts?
i just don t want to be down a long while, waiting for parts. cooldude
Enjoy the ride!
MP
North Dakota
« Reply #9 on: October 27, 2009, 05:17:53 AM »
Yes, you can drill them out, then bolt back together.
MP
"Ridin' with Cycho"
franco6
Houston, TX
« Reply #10 on: October 27, 2009, 09:31:22 AM »
 cooldude 2funny
Enjoy the ride!
