April 01, 2026, 09:58:15 AM *
Author Topic: Has this ever happen to you ?  (Read 1281 times)
LadyDraco
TISE
« on: November 22, 2017, 02:25:29 PM »
This  is  the  way
oldsmokey
Mendon Massachusetts
« Reply #1 on: November 22, 2017, 02:34:15 PM »
Sneaky stuff it is. Grin
« Reply #2 on: November 22, 2017, 03:02:37 PM »
 2funny
good thing I only have a little tube......
How much trouble can it possibly cause    Undecided
But then again you have watched me take 3 hrs to "try" to do a spline service   uglystupid2
« Last Edit: November 22, 2017, 03:05:37 PM by Oss » Logged
Jess Tolbirt
White Bluff, Tn.
« Reply #3 on: November 22, 2017, 05:19:59 PM »
i put anti seize on one stinkin bolt and had that sh*t all over me
Valkyrie member # 23084
ridingron
Orlando
« Reply #4 on: November 22, 2017, 07:12:56 PM »
I have used it every day at work for years and still can't keep it where I want it. It does seem to go everywhere.
« Reply #5 on: November 22, 2017, 07:51:02 PM »
                   Kinds sorta like Navy syrup fer da hot cakes!  coolsmiley That syrup crawl up yer arm like da blob!  2funny  I have a small tube of the gold colored anti seize. You just KNOW what I been doin Before I gitz done!  Roll Eyes Stuff Not only migrates it propagates.  Lips Sealed RIDE SAFE.
« Reply #6 on: November 23, 2017, 03:48:56 AM »
Yep. I use a lot of it. Usually there is a learning curve to most things, this stuff is the exception.
DirtyDan
Kingman Arizona, from NJ
« Reply #7 on: November 23, 2017, 08:26:26 AM »
I’m getting flashbacks of pipefitting
We used “never seez”
Yeah it’s messy n spreads
Dan
« Reply #8 on: November 23, 2017, 08:43:43 AM »
"Stuff Not only migrates it propagates."
Now that right there is funny! Good luck, LD, looks like many here thoroughly understand you're plight...
« Reply #9 on: November 23, 2017, 09:04:47 AM »
That's the stuff that was used by builders of the "easy glasspack mod".  The mod that used heavy threaded steel water pipe to install glasspacks and straight pipes. Welded in a threaded reducer as collector and welded short nipples onto the glasspacks; used 2-ft threaded pipe as straight pipes. They had to use the anti-sieze on the threads and "exercise" them frequently - used a custom spanner to reach in there and break them loose and turn them.  Pipe threads were not intended for hot exhaust systems and they seize.   Stored the straight pipes and glasspacks in the luggage with anti-seize on them so they could change the sound at a ride-in (eg, quiet on the road with glasspacks; loud at the ride-in with straight pipes). Even wrapped in plastic, I can imagine the resulting mess.  DIY solution that was not well engineered.
I have used anti-seize on steel to aluminum threads.  Like spark plugs.  I actually had one of the alternator bolts break off on Deerslayer years ago, because Honda assembly did not use it.  That bolt stub is still in there.
« Last Edit: November 23, 2017, 09:10:16 AM by MarkT » Logged
threevalks
Letart, WV
« Reply #10 on: November 23, 2017, 10:37:06 AM »
A little dap on your buddies hat band goes a long way.
LadyDraco
TISE
« Reply #11 on: November 24, 2017, 04:47:52 AM »
 2funny
This  is  the  way
henry 008
BRP
willard, oh
« Reply #12 on: November 27, 2017, 12:11:51 PM »
had a young friend at another machine shop say the he doesn't use it anymore. "I put a smidge on a bolt, and found some on my girlfriend's but 2 weeks later!"
Safe Winds... Brother
Fazer
« Reply #13 on: November 27, 2017, 12:51:05 PM »
Good one, Henry
Nothing in moderation...
¿spoom
WI
« Reply #14 on: November 27, 2017, 03:26:11 PM »
Dan
Yup, our saying was, forget to use it, and the bolt "never sees" daylight again. That colloidal copper stuff is awesome on some dissimilar metals, I think the FelPro # is C5A.
Jess Tolbirt
White Bluff, Tn.
« Reply #15 on: November 28, 2017, 07:34:55 AM »
LOL now thats funny right there
