February 13, 2026, 11:17:34 PM *
Author Topic: Carburator problem?  (Read 1204 times)
vrider
« on: November 25, 2017, 06:06:33 PM »
97 Valk with 85,000 miles was running rough maybe misfire. Had the carburetors cleaned.
Now
Bike starts easy and no lack of performance but backfires between shifts and the engine gets uncomfortably hot after a while riding. No idiot light.
Does this sound like it’s time for carburetor rebuilding? If so, anyplace to send them out?
WintrSol
Florissant, MO
« Reply #1 on: November 25, 2017, 06:41:05 PM »
Now
That sounds like it is really too lean. The work you had done really shouldn't have caused this, so something went wrong with the reassembly. Hard to say without a close examination. Maybe the intakes are leaking, or the vacuum lines have cracks. A little rough handling with old rubber parts can cause a lot of relatively unseen damage.
da prez
Wilmot Wi
« Reply #2 on: November 25, 2017, 07:54:52 PM »
  Check for vacuum leaks. Did you put in new runner O-rings. Are all bolts and clamps properly tightened. Is the base line settings correct. If you did not de smog , it would be advisable. If you did a de smog , make sure it is sealed where it is needed.
 All else  , contact atticrat. He has done more carbs than you coule ever imagine.
                                   da prez
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: November 25, 2017, 08:48:55 PM »
                                   da prez
+1 on possible vacuum leaks.
If the air box was off, the intake tubes often don't seat correctly on the backside of the carbs.
Check the rest of the possible culprits too: http://www.valkyrieforum.com/bbs/index.php/topic,95448.0.html
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
