February 13, 2026, 11:17:55 PM *
Author Topic: Does anyone have the part numbers for VTX shock bushings?  (Read 2435 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« on: November 29, 2017, 05:38:13 AM »
Looking for the VTX rear shock bushings that fit our Valks.
h13man
Indiana NW Central Flatlands
« Reply #1 on: November 29, 2017, 06:22:01 AM »
www.rattlebars.com/cart/bushings.html
« Reply #2 on: November 29, 2017, 07:11:34 AM »
Gary's bushings are no longer available, as he is no longer with us.
VTX bushings that work with 1500 Valkyries: Honda 52489-HN0-671
Paladin528
« Reply #3 on: November 29, 2017, 09:34:38 AM »
do those work for the top AND bottom bushing?  I believe they are both the same.
« Reply #4 on: November 29, 2017, 10:07:22 AM »
Yes.  On the bottom there are two different steel bushings (1L, 1R) that need to be transferred from the old rubber/plastic bushings to the new ones, but the rubber/plastic bushings are the same top and bottom.  You will probably wear out three top bushings for every bottom bushing.
« Last Edit: November 29, 2017, 10:10:43 AM by Gryphon Rider » Logged
« Reply #5 on: November 29, 2017, 10:14:40 AM »
I have yet to wear out the VTX ones.  cooldude
_Sheffjs_
Sarasota FL
« Reply #6 on: November 29, 2017, 10:28:00 AM »
« Reply #7 on: November 29, 2017, 12:13:42 PM »
What's the difference between the VTX and the Valkyrie bushings?
SCain
Rio Rancho, NM
« Reply #8 on: November 29, 2017, 12:29:00 PM »
Doesn't Daryl sell the forever bushings for the VTX, check this link.
http://www.xf6-custom.com/aboutxf6.html
Steve
« Reply #9 on: November 29, 2017, 12:32:55 PM »
Material (durability) and colour.  Valk bushings are black and wear out quickly, VTX bushings are green and last way longer.  Both are the same shape.
« Reply #10 on: November 29, 2017, 12:34:36 PM »
Hmmmm. Thanks. Who knew? Obviously not me  cooldude
Another factoid to add to my list of Valk stuff.
« Reply #11 on: November 29, 2017, 01:14:54 PM »
Valkyrie:
VTX:
The VTX part says "upper" but works for upper and lower ends on a Valkyrie.
« Reply #12 on: November 29, 2017, 01:43:22 PM »
Yes, and they are good. But the VTX ones are pretty close for less money.
« Reply #13 on: November 29, 2017, 04:46:12 PM »
Rubber ones wear out.  Polyurethane ones don't.
Same deal with motor mounts.
« Reply #14 on: November 29, 2017, 05:40:01 PM »
A lot of VTX riders are using nylon bushings.
http://www.vtxcafe.com/showthread.php/61178-Shock-Bushing-Survey-Rubber-vs-Poly-vs-Nylon/page2
http://ohioxriders.proboards.com/thread/3940
http://www.vtxoa.com/forums/6-vtx-1800-tech-board/311050-poly-rear-shock-bushings.html?action=thread
The Honda part 52489-MW3-305 / the stock part # for my 2007 1800r, this bushing is black and very stiff.
The Honda part 52489-HN0-671 / the green polyurethane bushing - is a little softer and it is also about .020" taller in size, .020 bigger I.D, the O.D.'s seem to be the same maybe a minute difference.
https://grassrootsmotorsports.com/forum/grm/nylon-bushings/50124/page1/
« Last Edit: November 29, 2017, 05:51:06 PM by Vaquero (aka 98valk & CA) » Logged
« Reply #15 on: November 29, 2017, 05:54:34 PM »
^^^^^^^^ THIS and he guarantees them for life.....beat that deal...I have them on both me bikes.
« Reply #16 on: November 29, 2017, 06:28:23 PM »
Valkyrie:
VTX:
I remember the VTX ones being green and 2 piece ? But I'm old and don't remember well.  Wink
« Reply #17 on: November 29, 2017, 08:27:20 PM »
Adjust the angle of your laptop screen and you'll see that they are green compared to the black printing on the bag label.  They were never two-piece.
« Reply #18 on: November 30, 2017, 04:58:52 AM »
[/quote]I remember the VTX ones being green and 2 piece ? But I'm old and don't remember well.  Wink
[/quote]
only Daryl's are two piece.
on one of those VTX sites there is a guy using a two piece made from some type of metal. said he had 40k on them.
