January 30, 2026, 12:21:36 AM *
Author Topic: Hitch  (Read 2054 times)
V-SIX DS#121
Western NC
« on: October 27, 2009, 12:37:20 PM »
Does anyone have the measurements to make a Valk hitch?  Tks
« Reply #1 on: October 27, 2009, 02:55:55 PM »
Check the Texas board. I think someone over there does.
PAVALKER
Pittsburgh, Pa
« Reply #2 on: October 27, 2009, 04:16:26 PM »
Edit... on second thought  here ya go..... I just uploaded the pics.
« Last Edit: October 27, 2009, 04:26:40 PM by PAVALKER » Logged
John
MNBill
Southern Minnesota
« Reply #3 on: November 04, 2009, 07:04:03 PM »
How thick of steel did you use??? Does this one follow the fenders on the outside or hide behind the saddle bags or is it inside the fenders??
MNBill
SE Minnesota
PAVALKER
Pittsburgh, Pa
« Reply #4 on: November 04, 2009, 07:43:16 PM »
Fits outside the fenders and I think the steel is close to 1/4 inch thick.
John
MNBill
Southern Minnesota
« Reply #5 on: November 05, 2009, 03:24:35 AM »
Thanks, brother in laws work in fabrication, have to see what they can do for me.
MNBill
SE Minnesota
Bob E.
Canonsburg, PA
« Reply #6 on: November 05, 2009, 04:36:44 AM »
I started with that plan...but you can clearly see that there are some dimensions missing.  So I bought some 1/4" foam poster board from a craft store and made some templates right on the bike...making adjustments until I got it right.  Also, I changed the area around the holes...being a structural engineer, I didn't like that the holes were so close to the top edge of the plate.  So I made it so that the plate was 3" wide (1/4" thick) all along and put the holes in the middle.  I took the templates to a local fab shop and had them cut out and bent...total cost was about $120.  Here's a pic of the hitch bracket before I got it cleaned up and painted.
Sodbuster
« Reply #7 on: November 05, 2009, 04:23:04 PM »
Did you document what you ended up with for dimensions ??
VRCC # 30938
Bob E.
Canonsburg, PA
« Reply #8 on: November 09, 2009, 07:43:43 AM »
No...I just gave the template to the fab shop and they cut them out.
