April 30, 2026, 07:00:55 AM *
Author Topic: Michelin Commander II 200/55 17 on bike info.  (Read 5464 times)
Shrubbo
Australia
« on: December 16, 2017, 01:15:23 PM »
I decided to do this because why not. I have just burned (literally) the 3rd PR4 so I wanted to try something different and also the thought of a wider rear on the bike has always appealed to me.
Be aware right off the bat that this tire is outside the guide lines for this rim size as far as I understand it. I believe it recommends a 185 as the upper level for our 5.5" rims. As such some people probably quite rightly recommend not to do this. However if you are interested then here is some info for you.
Firstly... a final send off for my 3rd PR4 GT Smiley
https://www.youtube.com/watch?v=zlY899sUc48
General info.
OEM = 180/55 R17
What went on = Michelin Commander II 200/55 R17
I went down to the bike shop and asked them about the possibility of fitting said rim if I bought the wheel down. They were a little concerned about damaging the rim while trying to put the tire on so they wanted to see it first.
On inspection they said "yeah no problem, want it now?". Yes. yes I do. When it came out it did look pretty sweet I am happy to say, they even commented on it.
Trying to fit it to the bike wasn't quite as straight forward. My ATV jack can only go so high and the rubber was catching on the wheel studs. With the normal rubber I can slide it in and out. Not this time. If I could have lifted higher then probably no problem but I decided to stop messing around and pulled the left pipe off. No issues after that.
First visual impressions:
I understand this is all subjective but to me it became total win. It is only 20mm difference but it just hit the right spot. It is not a 240 but it doesn't look undersized anymore... it looks sweet!
Ride impressions:
I did around 550k's (341m) on Saturday and for me... well it just felt like I was riding my Valkyrie. Your mileage may vary but I don't know any other way to put it. It didn't seem to behave in any different way then normal. I know there must be some change there but perhaps the best part of half a metric tonne doesn't really care about a 10% gain in rear tire width? All I can say is I had a great ride and had it far enough over many times to be really damaging my actual pegs (I got new pegsavers on order, probably new pegs again if they don't get here soon hah). I did not run it at upper levels of speed performance but I do like to get her over on back to back corners.
Wet weather performance?:
NFI but I highly doubt they will be in the same class as the Pilot Road GT's. The PR4's had amazing wet weather grip but that will have to wait until it rains again and will update when I get to try it.
Here is a bunch of photos showing as best I could the clearances. Also there is one shot of the Speedo'/GPS. For the most part the actual road speed is spot on and I had to do some searching to find a few frames where the Speedo' and the GPS disagreed slightly.
In short for me... totally happy with the whole deal so far. I will update on long term and wet when these things occur.
Photo's:
https://photos.app.goo.gl/wqCClE7PuJjo9gUR2
« Last Edit: December 16, 2017, 01:20:15 PM by Shrubbo » Logged
2014 Valkyrie, crap stuck on it everywhere!
Parkway440
« Reply #1 on: December 17, 2017, 05:07:30 AM »
I been running that tire for a good while with no problems. In order to clear the wheel studs I let the air out of it and it slid right past them.
st2sam
N.E. Pennsylvania
« Reply #2 on: December 17, 2017, 07:02:22 AM »
Geeze, who woulda thunk?  ???  (IMO looks great)
Thanks for taking the time and effort to share.
It's much appreciated.  cooldude
ledany
Paris, FRANCE
« Reply #3 on: December 17, 2017, 02:02:41 PM »
shrubbo, where did you get your hand protections ? Could you please post the pix of how they are attached to the handlebar ?
It has been raining here for days and I'd like to put my handlebar sleeves back. I want to find something that could hold the handlebar sleeves in the adequate position when I'm speeding a little  Cool
Shrubbo
Australia
« Reply #4 on: December 17, 2017, 10:02:55 PM »
shrubbo, where did you get your hand protections ? Could you please post the pix of how they are attached to the handlebar ? ...
Ebay.
Search for handlebar wind deflectors
You will find a heap of different ones. Mine in particular are these ones I think.
https://www.ebay.com.au/itm/Universal-Motorcycle-Smoke-Handlebar-Hand-Guard-Wind-Deflector-Protector-Shield/281907155862?epid=888157121&hash=item41a2f9d396:g:DQ8AAOSwEzxYWOO8
Cheap and nasty but keep the cold off the fingers very well once you bend them to get the airflow just right. I also had to bend one a little to get the it through the throttle cables and the details are in the 2 photos I just put up. BTW they use the mirror bolt to attach with.
https://photos.app.goo.gl/VRkqPxyplISOFDBC2
ledany
Paris, FRANCE
« Reply #5 on: December 17, 2017, 11:58:47 PM »
Merci beaucoup shrubbo !  cooldude
wtm
Welch Village Ski Area, Minnesota
« Reply #6 on: January 03, 2018, 04:57:45 AM »
Thank-you for the detailed report and pictures. It clears up some questions I had. Looks good. Ordered the hand deflectors already.
Freedom, never let them take it away.
