November 15, 2025, 01:38:17 AM *
Author Topic: adjustments on shocks  (Read 1206 times)
kc5tf
« on: December 20, 2017, 07:41:21 PM »
 1 is the softest ride---5 is the stiffest ride--correct
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #1 on: December 21, 2017, 02:32:02 AM »
That would be correct.
« Last Edit: December 21, 2017, 02:33:50 AM by RDKLL » Logged
Kunkies
Charlotte, NC
« Reply #2 on: December 21, 2017, 04:24:06 AM »
don't go from 5 setting to 1 you won't like it. . . , rather 5, 4, 3, 2, 1 in steps
Joe Hummer
Arnold, MO
« Reply #3 on: December 21, 2017, 06:46:55 AM »
Its ok is you do...won't mess anything up...it will just make a loud noise as the the spring drops to the 1 position.
1999 Valkyrie Interstate
Kunkies
Charlotte, NC
« Reply #4 on: December 21, 2017, 10:28:29 AM »
Joe's right, when I did (truth be told) it scared the livin' sh_t out of me!   2funny
« Reply #5 on: December 24, 2017, 07:41:25 AM »
https://www.motorcyclecruiser.com/adjusting-rear-spring-preload
Basically, when ride height is overly high there is too little sag. The bike rides near the top of its suspension travel, it’s stiff, uncomfortable, and if you’re vertically challenged you may have trouble reaching the ground. If the ride height is too low, there is too much sag, the bike tends to move around on the suspension more than it should and the hard parts drag, a problem exacerbated by cruiser styling and the addition of a passenger and luggage. In general, most bikes are set with the preload on the low side for solo use. Turning it up a notch or two often firms up the handling, and of course any time a passenger is on board the preload needs to be adjusted upward to compensate for the added weight. Take some time to experiment with preload and learn how each change affects handling.
