BigM
« on: December 24, 2017, 05:41:35 PM » |
Any idea on a good mileage interval with the MP50 moly paste. Know the book says 10K. Running the car tire I have around that mileage. But the tire is not close to changing out. Any thoughts on what theyve seen with it at 10K. Or poss. good mileage to relube? Being winter thought it would be a good time but if no need i could wait.
« Reply #1 on: December 24, 2017, 06:00:59 PM » |
No more than 10K is my rule of thumb
BigM
« Reply #2 on: December 24, 2017, 06:54:31 PM » |
Sent ya a e-mail P.M. Thanks for the info.
« Reply #3 on: December 25, 2017, 10:22:44 AM » |
I've done 12000 with Guard Dog Moly BUT-disclaimer here-I'm more in line with Chris's recommendation of 10G on miles. And as an aside-though I've done the rear end maint a number of times I STILL follow the step by step stuff I have printed up. I was an Airplane wrench and air crew in the Navy and check lists do help. RIDE SAFE.
RudyF6
« Reply #4 on: December 25, 2017, 01:58:43 PM » |
This....... Ever since the time I did mine and thought I forgot the thrust washer between wheel and drive flange..... and didn't!
You can never be lost if you don't care where you're going! 98 "Tourerstate" (Std. with I/S bags/trunk) 98 Tourer solo ride 81 CBX
slider
« Reply #5 on: December 25, 2017, 02:00:25 PM » |
I do mine every year during winter down time--gives me peace of mine and something go do
a proud navy veteran
« Reply #6 on: December 25, 2017, 04:52:24 PM » |
I've talked to several promechanics and none of them use Moly Paste. Most use Bel Ray waterproof grease. My last Valk I sold with 155K and it still had the original splines in perfect shape.
« Reply #7 on: December 25, 2017, 05:06:01 PM » |
Oh no you didn't go there!!!
« Reply #9 on: December 25, 2017, 05:33:39 PM » |
Honda manual calls for paste, in the cup, but many use grease.
I feel the important thing is not which you use, but that you do the maintenance.
Also, that you clean the ports into the rear drive.
« Reply #11 on: December 25, 2017, 05:44:44 PM » |
In the pinion cup #13 there are two ports, or passageways, that go into the rear drive gear area. I don't believe anyone (except Honda engineers) knows for sure their purpose, but their there for some reason. I feel the reason may be for venting of the pinion cup.
« Reply #12 on: December 25, 2017, 05:51:57 PM » |
In the pinion cup #13 there are two ports, or passageways, that go into the rear drive gear area. I don't believe anyone (except Honda engineers) knows for sure their purpose, but their there for some reason. I feel the reason may be for venting of the pinion cup. these ports (holes)
« Reply #13 on: December 25, 2017, 05:57:18 PM » |
Wow, Cool  Where'd you get the pinion cup with the dragon in it?
BigM
« Reply #14 on: December 28, 2017, 11:44:35 AM » |
O.K Its been 11k miles since tire change and lube with car tire on my I/S. So went ahead and tore down to do the maint. At 11k all looks great. Still well lubed. I have used the Guarddog *Paste,(thinned out over time), Bel-Ray. Waterproof, *Grease. (was almost dry and stating to rust) And last time and now the Moly MP 50 *Paste has done the best to hold up. Now to check my other Valk Tourer. Bought it last summer so crossing my fingers somebody did it right. Thats the only draw back running a car tire which is o.k, Is that before did the maint when the m/c tire wears out. Now being that the ct gets more miles have to break it down mid ways of ct wear. But like said is a good thing otherwise would be buying a m/c tire also at this interval.
« Last Edit: December 28, 2017, 06:38:01 PM by BigM »
« Reply #15 on: December 28, 2017, 12:21:27 PM » |
IF you do proper maintenance throughout, use lots of good lube (I always overdo it), don't forget any parts (thrust washer), and put it back together in the correct sequence, I think the 10K interval can be extended somewhat.
IF water gets in there, from the Ujoint boot, power washers, days and days of rain riding, or however, all bets are off.
« Reply #16 on: December 28, 2017, 12:27:06 PM » |
Mine was at 13,500 miles upon death of Champiro tire. All "looked" fine. The longest I've gone. All previous were at motorcycle tire death. Normally around 9,000 miles. Both on Valkyrie and ST1300.
mello dude
Dayton Ohio
« Reply #17 on: December 28, 2017, 02:28:21 PM » |
Bel-Ray. Waterproof, *Grease. (was almost dry and stating to rust) And last time and now the Moly MP 3 *Paste has done the best to hold up. Now to check my other Valk Tourer. Bought it last summer so crossing my fingers somebody did it right. Thats the only draw back running a car tire which is o.k, Is that before did the maint when the m/c tire wears out. Now being that the ct gets more miles have to break it down mid ways of ct wear. But like said is a good thing otherwise would be buying a m/c tire also at this interval.
Could you list links of the exact products you are talking about? Its my turn on this stuff, although right now my garage is way too frickn cold!
« Last Edit: December 28, 2017, 02:31:07 PM by mello dude »
* There's someone in my head, but it's not me....... * Mr. Murphy was an optimist.... * There's a very fine line between Insanity and Genius..... * My get up and go, must have got up and went.....
« Reply #18 on: December 28, 2017, 03:15:09 PM » |
Mine was at 13,500 miles upon death of Champiro tire. All "looked" fine. The longest I've gone. All previous were at motorcycle tire death. Normally around 9,000 miles. Both on Valkyrie and ST1300. Yeah Paul, my bike tire rears never made it to 10K, so tire interval was it. With car tires going over 30K, I will split the difference at around 15K. I have no abnormal wear, and I am not worried. I've never had any of that dreaded rusty looking pasty crap in my splines (and no water).
BigM
« Reply #19 on: December 28, 2017, 06:38:52 PM » |
Could you list links of the exact products you are talking about? Is Moly mp50 Its my turn on this stuff, although right now my garage is way too frickn cold!
BigM
« Reply #20 on: December 28, 2017, 06:39:17 PM » |
Multipurpose Grease, MP-50(TM), 1 Lb
