February 14, 2026, 04:15:48 PM *
Author Topic: TC-W3 fuel additive  (Read 2624 times)
« on: December 28, 2017, 05:43:16 PM »
anybody using this for carburetor and upper cylinder lube?  It seems many are using it and there is much written on it by experts in the field.
http://www.ls1.com/forums/f48/been-testing-oil-91206/
« Last Edit: December 29, 2017, 07:16:55 AM by Vaquero (aka 98valk & CA) » Logged
Blackduck
West Australia
« Reply #1 on: December 29, 2017, 01:16:17 AM »
Common to use in early Cummins engines to make up for the "dry" Diesel that is supplied now.
« Reply #2 on: December 29, 2017, 04:39:13 AM »
yes I use it in my powerstroke. many report a consistent 1-2 mpg gain also and there was a diesel additive test which showed the same.
the link is about using it in gasoline engines also but a reduced dose compared to diesels. I've been looking for a gasoline high temperature lubricate for carburetors and upper cylinder and it seems I've found it.  cooldude
some are posting that it also stabilizes the ethanol fuel also.
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
« Reply #3 on: December 30, 2017, 08:41:08 AM »
Years ago, I asked a guy who owned a motorcycle repair shop about using "stabil".  He answered "don't know about Stabil, but I do a lot of carburetor work on ATV's, but seldom work on carbs on dirt bikes". He suggested using 2 stroke oil as a stabilizer in the winter. I used two stroke oil in the winter in the full gas tank for probably five years, never had a problem. Bikes would start fine and run fine in the spring, no smoke etc.  Last few years I have been using Seafoam,  but I think the two stroke oil does work. Never had a problem with the weed eater or blower leaving the two stroke gas in them over the winter.
CoachDoc
San Diego, CA
« Reply #4 on: January 02, 2018, 12:09:07 AM »
I’ve been adding 2oz. of TC-W3 oil per 5 gallons of gas in my older bikes for a while now. The goal is to enhance top end lubrication and to diminish some of the harmful effects of ethanol. How well it works only time will tell. I do believe it will enhance the resistance to rust susceptibility of the exhaust as some of the unburned oil will precipitate out in the pipes and baffles and coat the walls. I see no difference in performance, positive or negative.
« Last Edit: January 02, 2018, 01:52:20 PM by CoachDoc » Logged
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
« Reply #5 on: January 30, 2018, 04:19:21 AM »
My issue with gas additives has always been the containers leaking in my bags tickedoff tickedoff
I'm going to give this a try with these.
https://www.usplastic.com/catalog/item.aspx?itemid=42039
They seem to have good positive caps that hopefully won't fall off. Roll Eyes  Plus I can measure out an once at a time. cooldude
Researching the price and availability of TC-W3 oil, Super-Tech and Pennzoil seem easiest to get and the least expensive.
Can't believe the difference in prices, from $13.00  to $80.00+ per gal.
Roadog
« Reply #6 on: January 30, 2018, 09:04:49 AM »
When adding oil to the fuel tank ,as  it passes thru the main jets and displaces the amount of fuel the jets can pass.  I ran into this with my H2 drag bike when I switched it to premix from oil injection.  Oil injected into the cylinder dose not pass thru the main jets as it will when added to the fuel .  Just FYI.
Ride safe
Roadog
« Last Edit: January 30, 2018, 09:08:05 AM by Roadog » Logged
« Reply #7 on: July 27, 2018, 09:25:17 AM »
I have been getting a consistent increase of two MPG using this additive.
« Reply #8 on: July 27, 2018, 10:06:28 AM »
How did you measure to get that number?
