February 14, 2026, 01:06:54 AM *
Author Topic: Yet another petcock question.  (Read 1754 times)
Cynic
Springfield, MO
« on: December 30, 2017, 01:17:40 PM »
I searched for "Pingel" and found the 1311-CHV as the recommended model for the Valkyrie. Unfortunately, that's more than I was wanting to spend ($230 from Pingel, $180 on Amazon).
What is the practical difference between the 1311-CHV and the 1311-CH? I realize one has the vacuum and the other doesn't, but what difference does the vacuum really make? I'm not a mechanic, so you have to use single-syllable words to make me understand sometimes. I also saw where others used the non-vacuum version, but what else had to be done to make it work right?
Thank in advance.
Pete
« Reply #1 on: December 30, 2017, 01:47:03 PM »
On vacuum vs non vacuum, simply block/cap the unused vacuum port.
The vacuum petcock stops fuel flow when the engine stops other does not (you must turn it off).
« Reply #2 on: December 30, 2017, 01:52:52 PM »
I would recommend not getting the vacuum one. The non vacuum one should be around $100
Red Diamond
Beaumont, Texas
« Reply #3 on: December 30, 2017, 03:45:50 PM »
If you still have the OEM petcock, save yourself some money, get a cover set for it, you will be just fine.
« Reply #4 on: December 30, 2017, 04:36:31 PM »
+1  cooldude
Cynic
Springfield, MO
« Reply #5 on: December 30, 2017, 08:46:26 PM »
I already did, but it still has a small flow-through. Not going to mess with trying again. I've got a mechanic lined up to change the petcock and do a full once-over, but I have to get the parts beforehand (petcock, oil, filter).
« Reply #6 on: December 31, 2017, 12:01:26 AM »
 uglystupid2
« Reply #7 on: December 31, 2017, 09:56:17 AM »
Changing the fuel valve is easy and changing oil is even easier.  Riding a Valkyrie is going to be an expensive proposition if you are going to pay for every bolt that needs turned.
« Last Edit: December 31, 2017, 10:43:18 AM by Chrisj CMA » Logged
rockbobmel
Greenfield MA
« Reply #8 on: December 31, 2017, 02:53:09 PM »
You guys got me freaked out about Hydro-Lock!  I just got my Valk in earlier this month.  A 2002 with 12,400 miles.  I just drove it back, put a bunch of  StarTron in, ran for 1/2 hour, turned the petcock to off, batt out and covered it....
2002 Valkyrie GL1500CD
1996  Shadow 1100 ACE
« Reply #9 on: December 31, 2017, 03:44:39 PM »
Some just aren't good at working on bikes, but are at riding them.
https://m.youtube.com/watch?v=_VrFV5r8cs0
Harryc
Sebastian, Fl
« Reply #10 on: December 31, 2017, 05:28:32 PM »
I hear you Bro. Chris does have a point. It's a wonderful bike but they are getting up on 20 years old now. if you need a mechanic to work on them for little things, it could get pricey because they can be needy at times...not often but still. Happy New Year to you and Brenda.
« Last Edit: December 31, 2017, 05:33:10 PM by Harryc » Logged
« Reply #11 on: January 01, 2018, 03:59:00 AM »
Thanks Harry. Happy New Year to you also. Sorry about the weather you guys are getting.  Angry
Hooter
S.W. Michigan
« Reply #12 on: January 05, 2018, 04:48:55 AM »
Get a manual, read, and start doing things yourself. Chris is right.
