February 13, 2026, 11:17:57 PM *
Author Topic: Carburator cleaning  (Read 1925 times)
1NorthRyder
Elliot Lake, Ontario, Canada
« on: January 02, 2018, 09:43:35 AM »
Can the carbs be disassembled cleaned and reassembled without replacing all the gaskets or are you wise to order a kit from redeye, I believe the one I saw was about $85?
1NorthRyder
« Reply #1 on: January 02, 2018, 10:03:22 AM »
Looks like Redeye doesn't ship to Canada.Sad
Beardo
Regina, Saskatchewan Canada
« Reply #2 on: January 02, 2018, 10:10:01 AM »
I’ve ordered from redeye, they shipped to Canada. They even issued me a rebate when the actual  shipping was less than they had estimated.
Call them if you want to be sure.
1NorthRyder
« Reply #3 on: January 02, 2018, 11:18:45 AM »
Found out I could order from them on e-bay to Canada but not from them directly. At least I can get them.
Beardo
« Reply #4 on: January 02, 2018, 12:26:26 PM »
Ah right.  That’s what I had to do too.  cooldude
Pete
« Reply #5 on: January 02, 2018, 12:28:53 PM »
Just for a normal jet and bowl cleaning I usually do not have to replace anything. otherwise yes just order the kit.
« Reply #6 on: January 02, 2018, 01:45:44 PM »
I've had well over a dozen sets of carbs open for jet replacement and cleaning and have yet had to replace a gasket.
« Reply #7 on: January 02, 2018, 02:42:35 PM »
Is it something that a fuel additive couldn't fix?
1NorthRyder
« Reply #8 on: January 02, 2018, 11:59:34 PM »
I’ve tried fuel additive but no improvement. I figured since I can’t ride for four months it was a good time to do a bunch of work on the bike.
flash2002
Montreal, Que
« Reply #9 on: January 03, 2018, 01:12:49 AM »
Red eye will ship to Canada. I ordered a few times, just send them an E-Mail  and he will give you the price for shipping. They are good sets, I just finished cleaning my carbs and installed new bowl gasket. If your going to do the carbs, change all the seal, the old ones will leak in time.
« Reply #10 on: January 03, 2018, 06:38:19 PM »
Which cleaner and what ratio fuel/cleaner did you use?
What problem are you having, I don't remember if you've already written about it.
« Last Edit: January 03, 2018, 06:46:47 PM by gordonv » Logged
1NorthRyder
« Reply #11 on: January 04, 2018, 04:23:34 AM »
"Which cleaner and what ratio fuel/cleaner did you use?
What problem are you having, I don't remember if you've already written about it."
Last summer while travelling through Montana I ran the bike bone dry and must have sucked something into the carbs. I did get it running reasonably well after using an STP fuel cleaner but feel it is only at about 85%. Most rougher running is at low in-town speeds. I've ordered a full set of gaskets and a Digi-Sync as I decided I have all winter to play so I might as well do the job right. I also ordered the Shiny De-Smog Kit and a K&N air filter, along with a whole bunch of other stuff like oil, filter, tire, grips, and speakers. My wife let me buy it all because she figured it was better to have me out in the garage than under her feet. I just bought this Valk a year ago and now that I've ridden it for a year decided to do all this work to really get to know her insides a little.
« Reply #12 on: January 04, 2018, 04:46:39 AM »
A couple suggestions. I ran a K&N filter for a couple years. Didn't really like it and switched back to OEM. Sounds like some of your slow jets might be clogged. Won't be hard to get them clean. I'd also consider a DanMarc shut off while you've got it tore down. If so, go with the .250 orifice unit.
« Reply #13 on: January 04, 2018, 08:45:58 PM »
Since you are having a problem, I would suggest removing the K&N filter, dump an OEM style, even a used one, in.
If you have only used the one cleaner, try more/others. Berryman's B12 is the one of choice. I get it for less than $5 at Walmart in WA. I but 1/2 can in 1/2 a tank of fresh fuel.
In Canada, I would start with Techron. Can't suggest the ratio, but think the same 50/50.
Sputtering at low speed, then you need to ride the bike at low speed in high gear (low rpm), with the cleaner in the tank. Driving means you can enjoy the ride and not worry about cooling.
Some have reported using 3 different (a long time ago now) cleaners, and each one seemed to clean the jets just a little more, till it as running 100% better.
I just got a car given to me that wasn't running (cranks, but wouldn't start [sputter a little]). Guy had it towed to a repair shop, paid $ for different repairs. He had enough of it, and was going to get it towed away and crushed.
It took me 8 hours over a week, research, testing. In the end, fouled plugs with a larger gape, and suspect bad fuel and fouled injectors. Re-gaped, added B12 and fresh Chevron with Techron fuel, and 1/4 tank later, car starts every time.
1NorthRyder
« Reply #14 on: January 05, 2018, 02:34:59 AM »
I currently have the OEM air filter on the bike but when I’m riding it’s ussually long rides so thought I would try the K&N this year. I’ve actually tried several fuel cleaners since last June when I ran out of fuel, they have helped but I still don’t think it’s 100% which is why I decided to disassemble the carbs and clean them properly.
« Last Edit: January 05, 2018, 02:38:51 AM by 1NorthRyder » Logged
Bone
« Reply #15 on: January 05, 2018, 03:05:28 AM »
We have had a few members buy new slow jets the cleaning wouldn't get them 100%.
« Reply #16 on: January 05, 2018, 04:01:47 AM »
yup cooldude
Unless you like to gamble that you got em clean, if not, you get to pull the carbs again.
« Reply #17 on: January 05, 2018, 04:15:51 AM »
I usually go 25k with the OEM filter, and it doesn't even look bad then. Many like the K&N.
1NorthRyder
« Reply #18 on: January 05, 2018, 04:28:08 AM »
Oh Boy more money to spend. LOL. Ok so if I'm getting new jets what are the best and how do I know for sure what the right size is. As I understand it your jets are determined by modifications, altitude and temperature. Actually that may be part of my problem as I bought the bike on the east coast and the altitude and temperature are very different.
davit
Deerfield, WI
« Reply #19 on: January 05, 2018, 02:46:57 PM »
Pull the carbs and do it right.  Buy OEM sized slow jets, I believe 35's, don't get drawn into upsizing to 38's.
« Reply #20 on: January 05, 2018, 04:13:51 PM »
yup cooldude
Ultra sonic cleaner with Krud kutter will make the old ones new again.
« Reply #21 on: January 06, 2018, 07:51:31 AM »
yup cooldude
I know many have these.  What does one of those puppies go for?
« Reply #22 on: January 06, 2018, 03:26:01 PM »
What RPM? This is why I mentioned you need low RPM. So long trips at 3K rpm won't do anything to the slow jets. You want it to idle, 1-2K rpm, which is why riding slow in high hear (low rpm), which would also allow cooling of the engine.
But then, I'm trying to avoid pulling/cleaning the carbs at all costs (time/place to fix).
I was thinking just the same thing. Seems I can get a jewelry one for $50. I figure if it fits, it will work. Even found a few (more expensive 2L volume) locally in CL.
« Last Edit: January 06, 2018, 03:32:00 PM by gordonv » Logged
1NorthRyder
« Reply #23 on: January 07, 2018, 01:16:16 PM »
Well the carbs are off and disassembled. They do have a bit of dirt in them, like a fine red sand. The jets all look pretty good but I’m betting water that fine stuff is is what has been causing my issue. Any suggestions on a good way to clean out the inside of the gas tank while I’ve got it off or should I just put a little fuel in it and swish it around and dump it a few times?
1NorthRyder
« Reply #24 on: January 07, 2018, 01:19:03 PM »
I also installed the Shiny Desmond Kit today, that went pretty easy. Gotta love the YouTube videos guys have posted both for the carb cleaning and installation of the Desmog kit.
dancnman
Houston, Texas
« Reply #25 on: January 07, 2018, 02:07:46 PM »
Take the valve out of the tank and as you said swish some fuel around in it a few times. I have a small Ultrasonic Cleaner that will make your jets and other things like new. Like your wife's jewelry to get her on board. And your gun parts etc. I always use Berrymans B12 in my bike. It will absorb some water/moisture and burn it. Cheaper than Sea Foam and I think better. Good luck.
Reality is that thing which does not change simply because I choose to ignore it.
