March 15, 2026, 04:12:05 PM *
Author Topic: Have u seen this lift adapter before?  (Read 1435 times)
Flrider
Jack
Kissimmee FL
« on: January 03, 2018, 11:11:45 AM »
Just came to posesión of this lift adapter.
I have one on my interstate, the kind that stays on all the time and I also had the red one that you only use when working on the bike and that most forget to take off when done  Grin
This one I have never seen before and looks like it stays on the bike.
Anyone have any info, good or bad reviews?
« Last Edit: January 03, 2018, 11:15:08 AM by Flrider » Logged
« Reply #1 on: January 03, 2018, 11:45:52 AM »
Homemade by someone with fabrication skills?
« Reply #2 on: January 03, 2018, 12:16:48 PM »
That looks a lot like my home-made wood one, without the base.
Course my wood one is old and grease/oil stained pressure treat with a much nicer patina than black steel.
And the wood ones don't screw down to anything.  Once you sit 900lbs on it, it almost never escapes.   Grin
« Last Edit: January 03, 2018, 12:21:05 PM by Jess from VA » Logged
Avanti
Stoughton, Wisconsin
« Reply #3 on: January 03, 2018, 01:27:21 PM »
That is a center stand upper; that mounts to the frame. Looks to be made by Rivco, 1/2 of a $450.00 part.
The rubber pad puts pressure on the rear of transmission to try to keep from twisting the frame cross member.
« Last Edit: January 03, 2018, 01:35:59 PM by Avanti » Logged
Flrider
Jack
Kissimmee FL
« Reply #4 on: January 03, 2018, 03:23:24 PM »
Well, there you go.
Thanks for the responses, have not had a center stand so did not occur to me that it could be part of that set up.
Now I know and the mystery is solved cooldude
